720 Propane
James Marburger
06-15-2005 08:38:41
I recently purchased a 720LP that I am farming with and I can only get 4-5 hours on a tank of fuel. I have put points, cond. plugs in it and I had to replace the vaporizor to a Century M-6. I can't find any leaks, but I feel this is too much fuel to be using. Can anyone please help me?
Thanks James
Frank M.
06-15-2005 19:09:46
 Re: 720 Propane in reply to James Marburger, 06-15-2005 08:38:41
In the early 70s I spent a lot of time running a 720 lp. During the summer we'd work 13 hour days, and rarely would we need to fill more than once a day. Most of that time was pulling a 14' tandem disc. We never opened the vapor valve during the summer. Always used the liquid. Back then I didn't even know what the vapor valve was for.
I don't know enough about them to even suggest what the problem is, but you're using way too much fuel.
Hope this helps
Frank M.
Glen in TX
06-15-2005 12:05:53
I ran a 730LP some and that does sound like using more fuel than I remember. Going thru 2-3 tanks a day wasn't unusual though. I too wonder if your guage is right? Can't remember the 720/730 tank capacity but it was 39 gallons for the 70 and at 85% would be 33 gallons. How fast you fill it and temp will affect that also. You want to run on vapor for about a half hour when tank gets lower before filling to get more filling capacity too by reducing the tank pressure. The load you are pulling, engine condition-compression, and air intake obstructions can affect fuel useage. You can sometimes find nasty mud dauber nests in the intake or birds nests under the grille blocking that. You didn't get the HP per hour ratings with LP that diesel and gasoline produced but during the time these tractors were made that was made up by lower fuel price.
buickanddeere
06-15-2005 12:03:37
Has she been hooked to a dyno? If she's wasting fuel the HP numbers will show it. You can also tune the spark and mixture for peak efficiency on the dyno too.
Mike M
06-15-2005 11:01:14
Two things I can think of ? Are you getting the tank full or is the gauge not working correctly ? And also those tanks are small and those big gas engines are thirsty 5 hours at 2 gals per hour minimun ? thats 20 gal I wonder what that tank is rated to hold ? Hopefully someone with some real world in the seat time on a 720 LP will chime in.
Woodrow Caul
06-15-2005 20:46:36
 Re: 720 Propane in reply to Mike M, 06-15-2005 11:01:14
I mow hay witha 720 LP. Its a new 10' vermeer disc mowere and it works pretty hard in good hay. It will stay against the governor most of the time. I can get about 10% of a tank per hour but the percentage gauge is not acurate. It is a liquid level gauge and the center of the tank holds more. I.E. around 60-40 percent lasts longest. An m-6 is a good replacement but is designed for larger engines. Check to see if it has a load adjustment like an Impco. You have to set load according to job at hand or it will eat fuel. I pull a Moline and leave load set on Max. but dont run it much. Have to set it back for parades and the like it will eat fuel. Drop me a line if you have more problems, not too many LP's around this site.
