14T knotting problem
JSS
06-15-2005 04:18:35
Help My 14T is double knotting on one side how can I fix problem
Paul Svetec
06-15-2005 16:09:55
 Re: 14T knotting problem in reply to JSS, 06-15-2005 04:18:35
We had a 24T and it would double knot sometimes because of poor twine. Try switching to nylon twine. Also as the parts wear out in the knotter we began to have more problems.
old
06-15-2005 07:07:51
First thing you need to do is go get a manual from JD for that baler. It has an area in it for trouble shooting the knotter.
John T
06-15-2005 06:49:13
JSS, in my day (when I used a 14T) I could have better answered your question, but its been too long but I have some vague recollections till someone more recently experienced rescues you.
Best I recall when the twine hang on the bill hooks it was either cuz they werent scoured up all shiny yet or else their tension was a tad too tight. You may try n buff them a lil or else run their tension a bit looser for a while if they are already shiny. For the twine to get there, the needles must be placing it correct and the twine discs holding it and the tucker fingers pushing it back, so Im thinkin a bill hook problem fer now or else..... ... Another thing that comes to mind are the twine knives are very dull n not cutting the twine nice n easy ????? ???
Sorry, no warranty on this one
John T
Jason Z in MO
06-15-2005 11:42:44
 Re: 14T knotting problem in reply to John T, 06-15-2005 06:49:13
I have a New Holland S69 (which has been an great baler) the only problem I have had with the knotters is what John T describes. The bill hook was worn out causing the problem you are talking about.
I believe the knotter assemblies are the same at least the operation is the same. Very interesting piece of engineering!
The book is really a must.
JSS
06-16-2005 02:41:12
 Re: 14T knotting problem in reply to Jason Z in MO, 06-15-2005 11:42:44
Yes I have the book but they do not talk about double knotting, That is why I come to you guys. I have been reading some of the other problems that have been taken care of with some help. I think by posting and asking questions,that someone could say the little thing that I have just over looked.I am making a list of responces and will start rereading them and I am sure it will be right there. As we all know the hay won"t bale it"s self.
The extra help is nice to have. JSS
Jason Z in MO
06-16-2005 09:15:18
 Re: 14T knotting problem in reply to JSS, 06-16-2005 02:41:12
JSS,
As the other comments have said by now these old balers and knotter mechanisms have plenty of worn parts so your symptom can be caused my many things. The other problem is when you look at them in a static state it takes a bit of studying to understand how they work. When you are running the machine you can watch the knotters trip but it happens pretty fast.
Follow your manual make any adjustments required. Compare the good side with the problem side. Sometimes the twine will get wrapped around the bill hook and cause this problem but that will be very obvious.
I have always run sisal twine. I have HEARD plastic twine does not function well in the older knotter designs. I don"t know this first hand, only what I have heard.
Where are you located? You might be surprised how close someone on the board might be and offer to come over and lend a hand.
Good luck!
