Gentlemen,Thank you for all your help and advice. This is a follow up just to let y'all know what the deal was. I bought a new voltmeter since the other one was giving me high readings (I tested it on my pickup, same problem.) Had low reading on both tractor batteries, so I charged them. While charging, I started to look at all the electrical connections to the batteries, alternator, etc. and discovered what I think was the culprit: the positive lead on the alternator had broken inside the insulation about a half inch up. So, while the tractor was dead, I was getting volts from the alternator, but once it was started I have a feeling the vibrations were screwing it up. So, for 50 cents I bought a new terminal and cut the wire, stripped it, and installed the new hookup. After the charge, I started the tractor and measured the voltage coming out of the alternator. Reading at high idle was 14.2 volts (which, I believe, is spot-on.) Same at the batteries. At low idle, the battery light on the dash illuminates and I'm only reading about 13 volts from the alternator. I let the thing run for about a half hour, then killed it. It cranked right back up (something it wouldn't do before.) So again, thank you all for your help! I'm sure this won't be the last time...isn't it great having a plot of land? We've dubbed our tract "Poverty Bottom". ;-) Blake
