Dave, if she has 100 lbs of compression PLUS if you can somehow turn her over slowly stopping near TDC on compression and you dont hear a lot of air leaking out the carbs intake, THEN IM NOT THINKING SO MUCH OF A LEAKY INTAKE VALVE AS I WAS EARLIER. THEREFORE, if she leans out and needs choke to run and theres good fuel flow out the carbs bottom drain cock plug as I instructed earlier, im thinking EITHER a vacuum leak like at the manifold to head,,,,, ,,, or a carb to manifold vacuum leak,,,,, ,,,or still an internal carb problem (such as the nozzle or an idle circuit still plugged). NOWWWWW if you can keep her running a lil bit, even with some choke as needed, have carb cleaner or WD 40 or an unlit propane torch and spray all around the manifolds base and the carb to manifold junction etc and if she speeds up or smoothes out, you found the vacuum leak. BUTTTTT T if it needs choke to run,,,,, and theres no manifold leaks,,,,, and the compressions over 100,,,,, , and you cant hear any valve leaks,,,,, , and the valves have sufficient lash,,,,, ,Im still thinking an internal carb problem!!!!! !!!!! !!!!! LAST THINGS TO TRY Try opening the carbs idle n load needles more n see if she ever clears up????? Remove valve covers and check all valve lashes?????Do the listen for leaky valves test again,,,,, Im runnin out of smarts lol. About the only other thigns to look at are shes timed extremely slow or the gas is stale or the sparks weak, but with its compression you mentioned, Im back to a non valve vacuum leak or a carb problem assuming the ignition is anywhere near correct. Keep tryin, let us know John T
