JD 50 Live PTO Overhaul Troubles...
jdbill
06-13-2005 17:28:38
I read several other posts out here on overhauling the PTO, and based on the recommendations, went to JD and blew the $300+ and bought a 'kit' with all new drive disks, facing disks, end plates with facings, and springs (the ones under the cam as well as the ones that go through the discs). Now that I'm getting it put back together, it just seems like everything is too tight. According to JD, my serial number (5002142) called for 7 drive discs and 6 facing discs. I can get it all in there and get the snap ring on, but with the adjusting cam backed all the way off, I just can't get the thing to engage (it just seems like there's not enough room for it to happen). I've double and triple checked everything else to verify it's back together correctly. I'm curious how loose or tight the discs should be with the clutch disengaged (with mine disengaged, I can barely turn the drive discs by hand). I noticed in JD's manual that some of the later models (I think) called for less discs. I was going to try removing 1 drive disc and one facing disc, but the 3 new springs that came in the 'kit' are MUCH heavier than the old ones, and don't want to compress that small. Before ordering the kit, I had ordered the 3 springs individually, and they are more like the old ones I took out. Anyone out there experience anything like this? There was also one shim under the brake plate. Should I remove it when overhauling the PTO? Thanks in advance for any help!!!!
Mike w J
06-14-2005 15:41:30
 Re: JD 50 Live PTO Overhaul Troubles... in reply to jdbill, 06-13-2005 17:28:38
My dad now 75 bought a new 50 in 1952 and used it on an allis round baler and the clutch went bad real quick they added another disk to the clutch. they did not have to change anything but adjustment but it was harder to get the snapring on the shaft. he said the next year or so they came from the factory withthe extra disk. if it won't snap into gear I would double check for a bent drive disk or a worn spline
ChuckW
06-14-2005 06:04:15
Sounds like someone has been monkeying around with the unit. The last unit I worked on I switched from another tractor. Just snapped the unit in and left it in tack. I was looking at the offical JD manual when I told you I saw 6 drive disk. Better go to JD parts and get a photo of exactly what to use.
Mike M
06-14-2005 04:37:19
JD has a kit ? Neverheard of this ?Everything used to be individully. Sit down with your parts book and study it and go by your serial # the answer is in there.
JDBILL
06-14-2005 05:59:23
 Re: JD 50 Live PTO Overhaul Troubles... in reply to Mike M, 06-14-2005 04:37:19
It's not a 'true' kit. But if you just try to buy the facing discs, their parts book cross references them to 7 of these, 6 of that, etc..... which ends up being everything necessary to rebuild the entire thing. Because of this, my assumption at the time of ordering them was that the one or more of the new parts were designed slightly differently than the originals and not interchangeable with each other, therefore requiring a rebuild from top to bottom. Unfortunately, my IT manual doesn't specify how many discs there should be based on serial number. I'll probably make another trip to Deere in the near future to take another look at their manual. The other interesting fact in this story is I'm rebuilding it because when I bought the tractor, the live PTO wouldn't engage/disengage. After removing it, I discovered that the majority of the actual facings were gone or near gone, and half of all the springs were broken. I don't know if someone else has already been in there monkeying with it or not. I'm still baffled..... .
Mike M
06-14-2005 06:13:55
 Re: JD 50 Live PTO Overhaul Troubles... in reply to JDBILL, 06-14-2005 05:59:23
On some of those units I do remember something about the springs subing to more.the extra new ones go inside of the original ones spaced out like every other one.
ChuckW
06-13-2005 19:17:25
If I were doing it, I would duplicate exactly what I had in place. Maybe the kit is for other models as well. In my manual there is only 6 drive disc shown. I would put it back exactly the way it came out.
