2030 Hydraulic Leak 3 Point????
Ponchobro
06-13-2005 14:09:48
Hello, My 2030 is leaking at the lower pivot points of the 3 point hitch. Is this a difficult repair? What is involved. Thanks
Tx Jim
06-14-2005 04:45:03
 Re: 2030 Hydraulic Leak 3 Point???? in reply to Ponchobro, 06-13-2005 14:09:48
Ponchobro,the lower attachment of 3pt is the load and depth control shaft.Not to complicated to repair.Drain rear end if it's not already. Remove retainer on each side and remove 3pt. arms. Place L&D lever in D and slide shaft out either side. Renew seals and replace everything. Tx Jim
Ponchobro
07-02-2005 06:21:50
 Re: 2030 Hydraulic Leak 3 Point???? in reply to Tx Jim, 06-14-2005 04:45:03
Thanks for the reply, I was wondering why the manual show's to remove the rockshaft housing? Again thanks for your help!!!
