JD 445 60 Mowing Deck
Dave Connell
06-13-2005 13:20:52
Help! I have had problems with grass accumulating under the 60" deck since I bought the tractor new 2 years ago. I have had to clean the deck every 3 mowing sessions...I then bought the mulching kit and found I had to clean after each cut. I've since removed the mulch kit and am back where I started. Is there anything I can do to prevent cleaning the deck so often? Can I drill a hole in the deck, insert a hose attachment, and then attach my garden hose to clean the deck? Any help would be appreciated. Thanks, Dave
Hoby
06-14-2005 08:36:42
 Re: JD 445 60 Mowing Deck in reply to Dave Connell, 06-13-2005 13:20:52
I have a 400 with 60in deck, had the deck powder coated, mowed 5 times this season and it stays pretty clean.
dlcleav
06-14-2005 13:10:05
 Re: JD 445 60 Mowing Deck in reply to Hoby, 06-14-2005 08:36:42
I sure wish I knew what I was doing wrong. I've never had grass accumulate like this before. I'm using the mulching blades that came with the mulch kit right now but have purchased the non-mulch blade from my dealer before with same results. I don't cut when the grass is wet. Is it possible to install the blades wrong? I'm also cutting at almost the highest level possible.
