24 volt ground on 4020
MGB
06-13-2005 12:39:23
Does the ground cable from the right hand battery negative terminal to the backside of my 1967 24 volt john deere 4020 have to be grounded to that bolt or can it be grounded to the tractor somewhere else? The bolt has become lose and the tractor will not crank unless pulled.
WTW
06-13-2005 14:04:37
 Re: 24 volt ground on 4020 in reply to MGB, 06-13-2005 12:39:23
MGB, If you are talking about the cable that connects to the back side of the starter motor, it must remain connected to the starter motor or failure to your electrical system will result. Do NOT ground this cable to the frame as starter will not work and neither will the rest of the electrical system of tractor. Sounds like you will need to have your starter / terminal repaired. Good Luck, DW
