730 d fuel pressures
bruce schepler
06-13-2005 08:27:48
have problem with 730d hitting on 1 cylinder, cleaned injectors and set valve lash to .22 cold. runs better. diesel man told me to check transfer pump to filters preesure and return to check valve pressure. can anyone tell me what they are suppose to be? i did check transfer pump to fuel filter pressure last nite, it showed 32psi @ fuel throttle. help?? thanks/bruce
MSD
06-13-2005 20:44:44
 Re: 730 d fuel pressures in reply to bruce schepler, 06-13-2005 08:27:48
I have a 730 that when I got it, the transfer pump wasn't even used, they ran a line directly from the tank to the filters. It never missed and ran fine. I never pulled anything with it to see how it worked under load though. Since then I have seen several others hooked up the same way.
jddriver
06-13-2005 20:10:44
I had the same prob on dads 730 turned transfer pump up to speck and the miss went away.It had 21lbs and Roy Ritter told me to turn it up and it worked.It is a very late 1960 model.I still dont understand why one will hit and the other will notSteve
Gpower
06-13-2005 14:22:44
Transfer pump pressures are as follows:
70,720, 730 up to serial number 7328620 should be 18-26 psi, at idle and full throttle.
730 after serial number 7328620 should be 57-67 psi, with relief valve pressure set to 35-45 psi.
PSI should stay within these ranges from slow idle to full idle. Transfer pump pressures are critical when under load, for your problem it could be air, but if one is hitting, the other usually hits within a few seconds if its an air problem.
Check and make sure the pumps are timed correctly and that the camshaft is actually pushing the plunger the correct distance within the injection pump. Next look for leaks in the injection compartment area.
If you need any other infe drop me a line.
Gpower
msb
06-13-2005 08:47:14
Can't remember exactly but the transfer pressure is not that critical.I am thinking 15-18 PSI is about right. Sounds like you have plenty.I would suspect you have some trapped air in the injection pump.They can be a real bear to get completely bled out.Does your tractor have the pressure return fitting in it.It was an impprovement that came after the tractors were first sold.It contains a spring and a ball that increases the manifold pressure of the injection pump.If so, you may have to remove the spring and ball to completely bleed the system.Reinstall it after bleeding.
Kevin L.
06-13-2005 11:36:13
 Re: 730 d fuel pressures in reply to msb, 06-13-2005 08:47:14
verify the exhaust valve is not being held open by the decompression level on that cylinder. if the motor has not run very hot or just repair the copper washers once the problem is found by swapping the injectors out and see if the problem moves, and loosen the lines at the injector to help bleed the air out, use caution it's high pressure. And was thinking the manual showed 12 psi but not sure, no manual in front of me..
F-I-T
06-13-2005 13:13:37
 Re: 730 d fuel pressures in reply to Kevin L., 06-13-2005 11:36:13
I have manual for the 730, but I thought some whewre I heard that the 730 fuel transfer pump was raised higher than that of the 70/gren dash 720's. I think 32 psi sounds correct.
I agree on the decomp lever holding an exhaust valve open. Just a little gap will make them miss a bit.
Frank
F-I-T
06-13-2005 13:15:37
 Meant to say... in reply to F-I-T, 06-13-2005 13:13:37
Meant to say I did NOT have a 730D manual, but recalled that the transfer pump pressure was higher than that of the 70 and green dash 720's.
buickanddeere
06-13-2005 19:02:54
 Re: Meant to say... in reply to F-I-T, 06-13-2005 13:15:37
Wasn't the fuel pressure raised when the new anti-reverse peanut cam was introduced?
720Deere
06-13-2005 19:12:29
 Re: Meant to say... in reply to buickanddeere, 06-13-2005 19:02:54
That's kinda what I thought. I have never checked the pressure on dad's 720, but his (7227727) has the relief valve/return line on it.
