2040 electrical system problem
BlakeTyner
06-12-2005 16:44:40
I have a bit of a problem. I own a "79 2040 and it just won"t start without charging the batteries. When it had to go in last year for another problem, I asked them to check the electrical system, as it had gone through 2 or 3 sets of batteries in a very short amount of time. When it came back, it came with 2 new 12V JD batts. That was fine for the first 8 or 10 starts, but after that...dead again.
A few years back I fried the factory alternator by accident and installed a new (remanufactured) one, which has worked well up until now.
I"m a novice when it comes to testing things, but I hooked the voltmeter up and here"s what I know so far:
With the tractor unable to start (no "clicking" when I turn the key) the voltmeter shows 22.5 volts when hooked to the battery terminals.
Voltmeter shows the same 22.5 volts on the alternator, when hooked to the positive and negative terminals (where the wiring bolts on).
I seem to have burned out my battery charger by using it so much lately, so until I get a new one I can"t charge the batteries and start the tractor. After I do that, should I test both locations again to see if the reading is higher on the voltmeter? What should the readings be?
If nothing else, should I take the alternator in for a bench test? I hear that places like Auto Zone will usually do it free of charge. It"s not a huge job to take the thing off, but I"d like to at least attempt to fix the situation.
Thanks in advance!
cannonball
06-13-2005 04:38:55
 Re: 2040 electrical system problem in reply to BlakeTyner, 06-12-2005 16:44:40
do you have volt meter on dc scale...an alt charges 13.8 to 14.2 volts and most of the time a battery will read 12.6 to 12.8 when not running...never seen a battery store more than that...you must have a drain on your batteries when not using them..unhook 12v going to alt(un hook all wires) and hookup light with tractor dead and see if it burns, if it does you have alt problems...have nice day may god bless
MSM
06-12-2005 17:16:14
A 2040 is 12 volts. If it has 2 12 v batteries they should be hooked positive to positive and both negatives to ground,giving you a strong 12 v setup. If you are correct in reading 22 volts,whoever put the batteries in,wired them incorrectly,giving you 24+ volts when charged. This has probably taken out the alternator,and possibly the starter. Since this was a dealer FU,I would contact them and ask them to make it right.
BlakeTyner
06-12-2005 17:28:44
 Re: 2040 electrical system problem in reply to MSM, 06-12-2005 17:16:14
Naw, the wiring is correct. I"m not sure if it makes a difference, but mine was made in Germany...
The way the batts are set up is as follows:
The left-side battery is grounded by a thick, bare, metal weave directly to the front of the batt compartment. The positive lead goes exits the underside of the batt compartment and crosses over to the right side of the tractor, where it bolts onto the starter.
The right side battery is grounded (it looks like) to the bottom of the batt compartment near the steering column. The positive lead exits the front of the compartment and also connects to the starter (both positives go on the same bolt on the starter.) The batteries are not, and have never been, connected together inside the compartment.
Oh, one thing I forgot to mention in my original post....the "battery" light on the dash will illuminate when the tractor is in low idle and then extinguish when in high idle or above. That"s always been the case, and I assumed when the light extinguished that it meant the alternator was charging.
Tx Jim
06-13-2005 04:44:35
 Re: 2040 electrical system problem in reply to BlakeTyner, 06-12-2005 17:28:44
Blake,if each positive bat.post is attached to starter and each neg. post to frame it would be impossible for voltage reading to get in the 20's.Maybe your volt meter is on the blink.As for batteries going dead,charge batt's with groung cables disconnected.Then take test light and attach from ground post to frame,with key and head lights off test light will burn if you have a short.Unhook one elect component at time till test light goes out.There's your problem short. Jim
MSM
06-13-2005 03:59:28
Check the battery voltage at the starter. If you are still getting 20 odd volts something is wrong. It is a 12V system,irregardless of place of manufacture.Depending on the age of it,the tractor has a voltage regulator mounted either under the dash(small black rectangular shaped) near the batteries,or possibly on the back of the alternator. Maybe take the alt. and the regulator to a shop and have them checked.If this option proves not to be cost effective,the tractor can be converted over to a Delco internal regulator alternator ($35)very easily.
