JD 2140 tech manual
Aussietractor
06-11-2005 20:48:12
To all and David Val, Do you know if there is a workshop manual that is published for late model 2140 JD? I can,t find any, other than I@T manual no JD202, but it doesn't have any info specific to 2140. It seems that the 2140 is made up of various components ie engine, tranny,and other bit and pieces. Could this be the reason? If that is the only reason, are the hydraulics and adjustments of them the same as the info for the models listed in JD202, those being- 2040 2240 2440 2510 2520 2640? I guess I am asking, is the 2140 transmission and hydraulics the same as those other models above? Any info along this line would be appreciated.
Aussietractor
06-12-2005 13:14:55
 Re: JD 2140 tech manual in reply to Aussietractor, 06-11-2005 20:48:12
Thanks you blokes, firstly, Mark you said that a neighbour purchased a manual. Can you confirm that it was for a 2140, you typed 2120, a typo error maybe?
David, a typo error of my own, I put I@T where as it should have been I&T Shop Service. They are published in the USA by Intertec. I'm sure I have seen them mentioned on forum elsewhere at YTMAG.
Does this make any difference to your replys. Thanks again
david val
06-12-2005 09:28:00
2140 is a stand alone tractor.i don't know the I@T manuals, but i guess they refere to U.S. models of which i am not familiar.
i am sure you can get the manual at deere. later models do not have the engine chapter which is a part of a sparate engine manual.
david
txgrn
06-12-2005 08:07:49
My neighbor recently purchased a repair manual for a 2120 from mother deere publications.
Mark
