Dave, Not to worry mate, if it really has fuel n fire n compression she has to run. Heres some thoughts. Initial thoughts are try new plugs and different choking and get good gas flow out carbs bottom (see below) and look at carbs top needle adjustments (see below) A FUEL PROBLEMS
1) Its normal for the sediment bowl to fill real slow PROVIDED the gas lines are all hooked up and the carbs bowl is full and the float n needle n seat all work CUZ IT AIR LOCKS. However, when you open the carb bowls bottom drain cock plug or the sediment bowl isnt tight n sealed yet at the top, then it ought to fill rapidly. 2) To check for restrictions at the gas tank outlet or the lil sed bowl inlet pipe or even a mash screen if it has one up inside the tank, have the glass bowl off n turn the valve on and gas ought to run out the lil top entry holes fast n smooth. IF NOT theres a restriction as mentioned above (lil pipe or mesh screen etc) 3) Once you insure good gas flow into and out of the sediment bowl, turn the gas on and open the carb bowls lower drain cock plug, and a steady stream of gas approx 1/16 inch needs to flow continuous DOES IT????? HAS TO FOR PROPER RUNNING OR ELSE ITS FUEL STARVATION 4) If not, theres EITHER a line restriction from the sed bowl to carbs inlet (Remove the inlet line and insure a good flow the size of gas lines ID happens) or else theres a restriction in the carbs side inlet strainer or the neede n seat assmebly or the floats not working right. UNTIL YOU GET GOOD FLOW OUT THE OPEN CARB BOWLS BOTOTM DRAIN COCK PLUG 1/16 INCH STEADY N CONTINUOUS, NOT MUCH USE IN GOING FORWARD 5) Once you insure a good gas flow to the carb and it flows good out the bottom per the above, lets look at choke and air inlet restrictions. 6) Check n make sure the choke butterfly plate is tight on its shaft and actually opens n closes n stays put relative to where its set externally????? 7) Make sure the air cleaners lower bowl is clan and not clogged up. 8) She ought to throw some white or black smoke out the stack when cranking, does it?? If not she may not be getting enough fuel or needs more choke. AFTER INSTALLING NEW PLUGS TRY DIFFERENT CHOKE SETITGNS TILL YOU GET SOME SMOKE OR VAPOR OUT THE STACK !!!!! !!! No fuel means no pop !!!!! !!!!! !!! 9) Carb settings. The initial settings are around 1 turn out for load n 2 out for idle needles, see where yours are set at and if close to there leave them as is. IF WAY OFF FROM THAT TRY THESE SETTIGNS B IGNITION PROBLEMS ITS POSSIBLE IF THE PLUGS GOT BADLY WET FOULED AND THEY NEED REPLACED. TRY NEW PLUGS 1) Remove the plugs but have wires attached n sides grounded n crank her over and insure BOTH plugs yield a good BLUE not a faint thin wimpy yellow spark. 2) If not post back what ignition you have and we will proceed. TRY NEW PLUGS YOURS MAY BE WET GAS FOULED. Check the spark for blue,,,,, ,,insure good gas flow out carbs bottom as I said,,,,try new plugs,,,,, ,try more choke till you get some gas vapor n smoke out the stack,,,,, ,,insure choke closes butterfly. Lemme know, good luck m God Bless John T
