HELP
Tx Jim
06-11-2005 04:37:32
Jim,seeing mist is slight leak which is bad,seeing stream is major leak which is worse.In dealer shop I always checked with no load on 3pt but load would probably make leak worse.The rockshaft will have to come off and control valves looked at.One thing I forgot is check valve clearance before r-shaft removal.Valves could be to tight.Tx Jim
