Is this rough 3010 worth $2000?
Joe Harrah
06-10-2005 20:12:54
Although I have this tractor at home, the deal is still not made. It wouldn't run right when I looked at it and we barely got it loaded. He talked me into spending some time with it to see just how bad the bugs all were. I got it running today, but I havent even taken it off the trailer. It has a 46 loader that is bent like a dogs hind leg. after putting hyd. oil in I found one of the bucket cylinders also has a badly bent ram. The loader didn't figure much into the price.
It has a wide front with car tires. 15.5x38 at 50%, but today I found a rotten spot on one between the lugs that is about to blow out. The charging system doesn't work and the batterys are weak. It has a broken hub cover on the front wheel and there's a lot of dirt in the brg. The guages don't work. The lights don't work and all of the emblems are missing. Some of the tin is bent and the piece of tin that covers the steering column is missing.
The other problem that has me concerned is that low range in the tranny has to be shifted just perfectly or it will just make grinding noises when the clutch is released.
My assumption was that a rough looking tractor that was ready to use would be worth the money, but I don't think this one will make it through the hay season before it goes down.
What is a good 3010 worth and what is the horse power rating?
Anybody want to throw in your 2 cents? I'd love to hear your thoughts.
Thanks, Joe
Dick Dillman
06-14-2005 01:31:08
 Re: Is this rough 3010 worth $2000? in reply to Joe Harrah, 06-10-2005 20:12:54
This sounds exactly like a 3010 with a 46 loader I purchased from a canning company in Bluffton In. I was going to fix it, but it had too many problems for me. A guy from somewhere in central Indiana came along and purchased it from me. I had an awful time getting it to run up to the railroad dock less than a half mile away to load it. It had a radiator leak, hydraulic leak, wouldn't go in several different gears, to name a few problems, but the guy wanted it bad,and gave me $3000 for it. DickD
Joe Harrah
06-12-2005 20:46:34
What a weekend! I decided the only way to make a truly informed decision about this tractor was to use it.
I spent some time fixing the 3 pt and guages and adjusting the clutch. I had to move the truck and trailer about 30 feet to unload the tractor, so I pulled the fuel stop on the tractor and threw it in park. I didn't want to take the time to put the chains back on the rear of the tractor.
Big Mistake!!
The tranny is junk everywhere below 2nd range. The tractor rolled. No major damage was done, thank God! I was able to fix everything that got bent on my truck and trailer, but one of the car tires on the front of the tractor cut a sidewall on the dollie crank of my trailer.
I knew better, I was just in a hurry. (Never time to do it right, always time to do it over!)
I put it on the bushhog and went to the pasture.
I ran it for 15 mins or so. found out the 3pt has no fine adjustment. the oil pressure started at 50 psi but shortly fell to 15psi wide open and 5 psi idleing warm. Low range only grinds, 2nd range will grind if you don't shift it just so. 2nd range is also too fast for bushhogging high stuff.
The wide front end and 3 pt are factory, but they are also needing lots of new parts. Very sloppy!
I'm gonna pass on this one.
Joe
P.s. Thanks to all of you who are willing to spend some of your valuable time giving guidence to those of us who can surely use it! It is appreciated!
jonfarmer
06-11-2005 16:19:44
Sounds to me like a parts tractor at best. Like others have pointed out, a loader thats been tortured like that means the tractor was beat and beat hard, obviously no maintenance was done and it wasn't taken care of, so it's probably totally mechanically trashed, such as the ranges in the transmission. The engine doesn't run good, that right there can mean serious $$$ to fix if it needs a complete overhaul. I hate to rain on your parade, but sounds to me like a 3 ton headache. You'd most likely have more than the price of a nice one in it by the time you fixed this one up. Run Run Run away and don't look back!.
davisfarms
06-11-2005 14:09:42
yes if you need it the engine running is worth nearly that plus wide front.I ounce ran a tractor that you put water in every 30 minutes and oil ervery 2 hours but i got by
Tx Jim
06-11-2005 04:22:49
 Salvage out. in reply to Joe Harrah, 06-10-2005 20:12:54
Joe,I don't think the price is out of line,assumming the wide frt. and 3pt, are factory. Your looking at around $1500 right there.I've seen where people are looking for these because their tractor didn't have them.Tx Jim
thurlow
06-11-2005 07:13:39
 Re: Salvage out. in reply to Tx Jim, 06-11-2005 04:22:49
I agree, it's probably worth the $2000..... .or more (salvage), but if I were looking for a tractor to use, I'd probably keep looking..... ....
Joe Harrah
06-11-2005 03:06:38
Thanks for the input. I have 3 tractors. Currently they are all three in my shop and unuseable. One is a deutz 40-06 that spun a rod brg and wiped out the crank. the other two are farmalls. An H and a super C. The H needs pto shift parts and I have a hydraulic unit for it, but is not installed yet. The super C has a piston and sleeve out and front main seal in the process of being fixed. Neither of these have 3 pt.
I need a second tractor with 3 pt anyway and I figured this one might be a way to ease my tractor woes, but the closer I look at it, the more I agree with the majority that my woes would only increase.
Bob, I know what you are saying. I'm 42 now but back when I was 14, I put a tune-up and a real good paint job on a '35 B that my dad bought in 1970 for $85. I took it to the Mississippi valley fair in Davenport Iowa for a 4H project and got a champion ribbon.
A few years later, I took the rear steel cutoffs that dad also bought with the tractor and welded a pair of hubs back in them. They turned out good enough that you could barely tell they were repaired. The story dad got at the sale was that the guy who purchased the tractor new, drove it home 2 miles on steel and when he got there, he hired a blacksmith to cut them down and put it on rubber. They did look like new.
Anyway, In the early 80's, I got married, bought a house, needed to scare up some extra $$ so I pondered the tractor. It got hot when we used it to rake hay and it didn't have any power, even though it had a hysler intake manifold. The compression was so low I could push the flywheel with my foot to start it. I knew it really needed an overhaul, which I couldn't afford, so I decided to let it go to a new home where it would hopefully get the tlc it deserved. I consigned it with the extra rear steel and sold it on a friends Oliver sale. It went to a lucky fellow in Illinois for a whopping $600.
I wish I could have a "Do Over" on that one! LOL
This 3010 is not beyond hope. It would make a nice restoration project, but that is not what I need right now. I'm looking for one I can hook up to a bush hog tomorrow and go to work with.
I will find out what his bottom dollar is, but I think he's gonna get this one back.
I'll let you know how it turns out.
Thanks again, Joe
Aussietractor
06-10-2005 23:01:23
Joe. It sounds like you would be paying too much for this flogged out beast, even in Aussie $$$$$$. Take it back real quick.
Bob
06-10-2005 23:13:40
 Re: Is this rough 3010 worth $2000? in reply to Aussietractor, 06-10-2005 23:01:23
Over the years, there's a lot of tractors that seemed a bit overpriced at the time, that I now wish I had "jumped on".
Nowadays, $2000.00 doesn't get you much, anywhere, but a $2000.00 GREEN tractor MAY appreciate over the next few years, and turn out to be a real bargain!
Aussietractor
06-10-2005 23:44:55
 Re: Is this rough 3010 worth $2000? in reply to Bob, 06-10-2005 23:13:40
Bob, I can see your point, but to bring this old girl back to shape, a lot of money will have to be thrown at her. It may never end. I think you are better of to pay a little extra in the begining and get something decent. I say buy once and buy well. Good luck to all.
RalphinWI
06-10-2005 21:40:24
I agree with your statement, "My assumption was that a rough looking tractor that was ready to use would be worth the money (i.e. $2000), but I don't think this one will make it through the hay season before it goes down." I admit I don't like problem equipment, but this sounds like 3 ton x $200/ton.
old
06-10-2005 21:33:58
To me for the price I'd take it back. Bent cylinders mean it has had a rough life and thats not good. I'd take it back and run fast, unless you can get it down to say $1000 maybe less.
