Gator carb problem
Our Farmer
06-10-2005 16:07:20
I have a year old Gator 4x6 I'm working on. She'll run and keep running if you crank her over and shoot in a little carb cleaner, but she won't run on her own. Disassembled the carb, float's not stuck and the needle valve is free. Pulled out and cleaned up the idle jet needle. Still no joy. Plenty of gas flowing to the carb fom the electric pump, clean air filter. Obviously have spark. There was some water in the float bowl when I took it off, but I would have thought I would have gotten it all out on disassemly. Any suggestions would be appreciated.
Scotty
06-11-2005 10:07:06
 Re: Gator carb problem in reply to Our Farmer, 06-10-2005 16:07:20
WHEN YOU TURN THE FUEL TO THE CARB. DO YOU HAVE A DRAIN PLUG YOU CAN PULL OUT TO SEE IF YOUR GETTING FUEL THROUGH THE NEEDLE AND SEAT. IF YOU GOT FUEL IN THE BOWL WHEN YOU TURN THE FUEL ON THEN MAKE SURE THE CARB IS FULL AND WHILE CRANKING THE MOTOR PUT YOUR HAND OVER THE CARB WHILE YOUR CRANKING THE ENGINE TO SEE IF YOU HAVE PLENTY OF SUCKING POWER. YOU SHOULD FEEL IT SUCKING YOUR FINGERS AND SEE A LITTLE FUEL WHEN YOU DO THIS. IF YOU DON'T FEEL THE SUCKING GOING ON THEN YOU MAY WANT TO CHECK YOUR COMPRESSION OR YOUR VALUE ADJUSTMENT. IF YOU DO SEE A LITTLE FUEL ON YOUR FINGERS OR IN THE THROAT OF THE CARB THEN YOU MAY WANT TO RUN SOME OF YOUR FUEL OUT OF YOUR TANK AND INTO A CLEAR GLASS JAR AND LET IT SETTLE TO CHECK FOR WATER IN THE FUEL. HOPE THIS HELPS !..... SCOTTY
Our Farmer
06-11-2005 15:46:45
 Re: Gator carb problem in reply to Scotty, 06-11-2005 10:07:06
Got it whipped. Was a load of contaminated fuel delivered to the farm tank.
