TONY MILLER WHERE ARE YOU?/ Help with 1010 power s
Justin Sanders
06-10-2005 08:17:00
Mr. Miller, I read your post of 6/5/04 re adding power steering to a JD 1010. As I am not knowledgeable with tractors, a lot of it went over my head. And, my problem is a little different. I have a JD 1010c with a power steering problem that I can't resolve. The pump can't produce enough pressure and I can't find a replacement after several months of trying every possible location avenue. So, I'm thinking that I'll approach the problem from another angle - as if the tractor never had power steering on it in the first place. Would your posting of 6/5 work? Or, do you know how I could run the power steering system off the hydraulic pump on the front of the tractor that handles the bucket? Any help you can give would be greatly appreciated. Very Best Wishes, Justin
