1941 B AND H FUEL
G2 DEERE
06-10-2005 07:30:51
A FRIEND OF MINE WHO RESTORES TRACTORS SAID IF I USE 100 OCTANE LOW LEAD AVIATON GAS IT WILL REDUCE VARNISHING IN THE CARB AND SINCE IT EVAPORATED QUICKER THAT IT WILL HELP WITH STARTING TOO. ALSO ADD 100 TO 1, 2 CYCLE OIL TO LUBE THE VALVES.
THESE ARE A SHOW TRACTORS ONLY.
Paul from MN
06-10-2005 13:34:51
 Re: 1941 B AND H FUEL in reply to G2 DEERE, 06-10-2005 07:30:51
I add Seafoam with regular old 87 octane in mine. It works great. The gas does not get old and my carbs stay clean. In fact I have a 44 A that needed a carb rebuild when I got it. I have not gotten around to it and by simply using Seafoam in the gas, it now runs far better than it did. So much better that I am no longer sure it is worth rebuilding the carb.
The stuff is amazing.
Pat Browning
06-10-2005 10:08:11
Aviation gasoline doesn't leave behind the solid, gummy residue when it evaporates, as regular automotive gasoline will do. It is the gooey varnish-like residue we all dread in our fuel systems -- of those engines that aren't subject to everyday use. And yes, I rather imagine using aviation gasoline in your small engines, especially toward the end of the season would be a great idea. Invariably, we hear the question of where to buy aviation gasoline. My expectation here would be your local airport!
Mike M
06-10-2005 10:27:51
 Re: 1941 B AND H FUEL in reply to Pat Browning, 06-10-2005 10:08:11
In my location Wooster Ohio,I have been told that they won't sell just anyone that av gas. You have to have "connections"
G2 DEERE
06-10-2005 18:15:03
 Re: 1941 B AND H FUEL in reply to Mike M, 06-10-2005 10:27:51
AS LONG AS YOU BUY SMALL QUANTIES AND TELL THEM IT IS FOR A ANTIQUE TRACTOR IT WILL BE OK
