16.9-38 tires on 14-38 rim
Gerald w pa
06-10-2005 07:26:36
Is any one running 16.9-38 tires on a 14" wide rim? Are they working ok? how do they look? How do they pull? I would be putting them on a JD 630
Thanks
720Deere
06-10-2005 10:20:05
 Re: 16.9-38 tires on 14-38 rim in reply to Gerald w pa, 06-10-2005 07:26:36
Just about everybody that has 16.9 tires is running them on 14" rims. That will work okay, but you might want to go to 16" if you are a serious puller. I jumped up to 16" over a year ago and it made a difference. Of course the 16" rims require different air pressure than 14" and it takes some experimenting, but once you get it right you won't be sorry. It really helps put more tire on the ground. I have see guys that have even wider rims with 16.9s.
