1950 A ground speed 4th gear
ELI
06-10-2005 06:12:47
I'm trying to spray with my A #658871 and the 2 books I have give 2 differant speeds for 4th gear. I ordered an original operators manual on ebay over a month ago, still waiting. If anyone with an original book would give me the ground speed I would be very greatfull. Thanks Eli
CMB
06-10-2005 09:21:51
 Re: 1950 A ground speed 4th gear in reply to ELI, 06-10-2005 06:12:47
"John Deere Tractors& Equipment" Vol 1 says 4 1/2 mph. Would be the same as 3rd in a "G".
Eli
06-10-2005 13:27:23
 Re: 1950 A ground speed 4th gear in reply to CMB, 06-10-2005 09:21:51
Thank You I'll set the sprayer accordingly Eli.
Dick Dillman
06-14-2005 02:07:46
 Re: 1950 A ground speed 4th gear in reply to Eli, 06-10-2005 13:27:23
My John DeereTractor data book gives 4th gear speed at 5.50 with 1100x38 tires, which were standard on late model A's. I was always of the opinion that the single stick transmission ground speed was lower than the ones prior to 648000 that had the hi-lo lever, but there is nothing in the data book that says so, except for low gear.
