730 4020 queations
Larry806
06-09-2005 19:45:35
One friend has a 730 I want to buy. He also has a set of front mount cultivators from a 3020 I would like to have if they would fit on the 730. Does anyone know if they will fit or what has to be done to make them work?
Another friend has a 4020 that is a bottle baby. He gives it a shot of either to start it when the motor is cold. I mean even on summer days. After it has been started & run it starts right up.I have started it with out either but it has to crank a lot to do it. When it runs it has quite a bit of blow by ,I also think there is a little seepage out the weep holes.This tractor only has 2600 hours on it. It has never done any heavy field work. It doesn't use any oil to speak of.any idea's or just overhaul it
Thank you for any help
ET
06-10-2005 07:06:52
 Re: 730 4020 queations in reply to Larry806, 06-09-2005 19:45:35
Did the 3020 have a wide or narrow front end? The cultivator is either an A4 for ajustable wide front end or a T4 for a tricicle front end. The unit for the wide front is easyest to change for tractor frame width. I adapted An A4 to fit on my 520. It was not to hard but took some timeThe front of the 3020 slopes forward at the top so I had to put a spacer behind the top button on front. The lenth of the arms coming back off the front bracket needs to be shortened. I used the newer side frame locator buttons, they are smaller diamiter than the old cultivators used. I welded tabs on the lower front crossbar to center it on the lower front plate and I had to change the location of the upper front hole to fit as well as shim out the button. The push bars from any of the old 400 or 40 cultivators will work.
matthies
06-09-2005 20:31:59
If the cultivator has the single 3 inch tube between the halves then no. But if the cult. uses the cone on top and the lip on the bottom then yes, but, those pieces have a wider bolt spacing between the tractors and the part of the cult. that uses the cone and lip will have to be widened and then your row spacing adjusted.(wider frame)And then you'll have to find the adapters for the pipes to raise the cult. from the three point arms. I think we had a parts cult. at the time to help with things. Otherwise not worth the trouble. My Uncle put his cult. from his 60 to 3010 and said never again.
