1946 JOHN DEERE D
TONY VAUGHAN
06-09-2005 18:44:03
MY OLD D STARTED BACK FIRING WHEN I TRIED TO START IT. IT BACK FIRED SO BAD IT WOULD BLOW THE OIL OUT OF THE AIR BREATHER. I WAS TOLD I MUST HAVE A STUCK VALVE. WE PULLED THE VALVE COVER AND THE VALVES WERE NOT STUCK. I THEN PUT NEW PLUGS, PLUG WIRES, POINTS, CONDENSER, AND NEW MAG.CAP. THIS DID NOT HELP, SO AS A LAST RESORT I REVERSED THE PLUG WIRES,I MOVED THE LEFT SIDE TO THE BOTTOM AND THE RIGHT SIDE TO THE TOP. IT STARTED AND RUNS PRETTY GOOD. ANY SUGGESTIONS IF THIS IS OK OR DO I HAVE A MAJOR PROBLEM? THANK YOU IN ADVANCE FOR YOUR HELP. TV
Dale in IN
06-10-2005 07:05:18
 Re: 1946 JOHN DEERE D in reply to TONY VAUGHAN, 06-09-2005 18:44:03
Tony:
Where did you find the points, condenser and cap? Was it at deere? I have been working on a 44 D sense Monday and I can come up with points but no condenser or cap At NAPA. It has a substitue condenser in it that is not fastened solid. I have come to the conclusion that the lag angle plate had slipped in it. Got it tightened yesterday but did not have time to try to start it. By the way it is a hand cranker. All I can do to roll it over.
John T
06-09-2005 19:53:27
Tony, if it works okay its likely okay as you have it. (You may wanna adjust its initial static start timing and/or its lag angle if its not up to par) Originally, most mags from the factory were top terminal to left plug and bottom to right. HOWEVER if the mag was a direct drive (NON reduction) like the Wico C or X and others, they fired their plugs at BOTH TDC's (Power and Exhaust) THEREFORE, if they are installed 180 degrees out of time, a simple top n bottom plug wire swap makes them run okay. HOWEVER, on the reduction drive gear mags like the Wico AP and some of the Fairbanks Morse n others, they have to be timed correct to work at all and a wire swap WILL NOT make them work if they are installed 180 out of time.
What mag you have??? Is it a base mount or a flange mount into the governor???
If its a direct drive mag like the Wico C or X and its 180 out but you want it to be as original (top to left bottom to right) then you can remove it and rotate EITHER the flywheel or the mags drive 180 degrees and reinstall it, or else just have the wires swapped as you do now..
John T Nordhoff in Indiana
Dale in IN
06-10-2005 07:18:03
 Re: 1946 JOHN DEERE D in reply to John T, 06-09-2005 19:53:27
John T:
You and Tony could not have timed your postings more timely. Your answers fit right in with what I am working on. I have cleaned the points and the mag inside and got good fire. Some times it will start but it has got to the point that it doesn't want to. Then I found the lag plate set at 25 degree to the left. That is facing the driver end. The screws holding the plate were not tight.So I have moved it back to 12 1/2 degrees as to one of your earlier postings that I had printed out for my file. I will try it again this morning. It is a Wico series C. It dosen't take to much turning on that big wheel to wear you out this kind of weather.
