3010 hydraulics
woodbutcher
06-09-2005 13:12:33
I installed a used frontloader on my 3010. It will lift 2 or 3 round bales and then all hydraulics shut down for a minute or two. When the system comes back up, it is not as strong as before. I've read about the closed center system in these tractors, and I'm sure it has a hard time supplying the large lift cylinders. But somebody mentioned a screen in the system somewhere. I've changed the fluid and the filter, but I can't find a screen.
MSM
06-09-2005 16:21:26
 Re: 3010 hydraulics in reply to woodbutcher, 06-09-2005 13:12:33
If you are using the clutch alot loading bales,you may be starving the hyd. pump. The transmission contains a pump that pushes oil to the main pump in the front.If you are on the clutch alot, the transmission isn't running enough to charge the front pump. If you are lifting a bale,put the trans in neutral and let out the clutch. Deere also had a reservoir that could be added above the front pump to give it some extra oil for loader/hi hydraulic usage. You might be able to find one in a salvage yard.
Maark
06-09-2005 13:55:33
You will lose 12-15 gallons of hydraulic oil when you remove that screen. Be Ready with catch pans.
G/MAN
06-09-2005 13:35:54
The transmission pump sump screen is located inside that round plug about 2 inches in diameter directly behind the tranny filter housing. Should take a 1/2" square drive to pull it out. If you have your foot on the clutch when trying to lift, you may run out of oil, as the tranny pump only turns when the clutch is engaged, and the tranny pump provides charge oil to the main pump. Yes, big cylinders can take a lot of oil, but the JD constant-pressure hydraulic system routes the return oil from the opposite side of the cylinder pistons back into the pump supply, so it's hard to run one completely out of oil.
woodbutcher
06-09-2005 13:45:05
 Re: 3010 hydraulics in reply to G/MAN, 06-09-2005 13:35:54
I'll check that screen, thanks. Would contamination from straight hydraulic fluid cause this problem when it mixes with hyd-trans in the system?
Tx Jim
06-10-2005 03:26:14
 Re: 3010 hydraulics in reply to woodbutcher, 06-09-2005 13:45:05
woodbutcher,if you are using a independant valve on loader be sure it for closed center and route return oil back to filter with a ported filter cover. Tx Jim
woodbutcher
06-10-2005 08:13:04
 Re: 3010 hydraulics in reply to Tx Jim, 06-10-2005 03:26:14
I got the closed center contol valve, but I routed the return to dump into the transmission housing at the back end. I didn't know the ported filter cover was available. Thanks for the info.
matthies
06-09-2005 20:16:13
I think that plug takes a 1/2 inch allen wrench, the later tractors use a square drive. chris
G/MAN
06-09-2005 15:26:31
It probably shouldn't, but if you have any doubts, by all means dump out the mix and go back in with a QUALITY transmission/hydraulic oil, ideally JD Hy-Gard, as it's formulated to work with the friction material on your brake pads and backing plates with a minimum of "chatter". Usually when a sump-screen is plugged enough to cause problems, it's due to material off the brakes. Whatever you do, don't use the el cheapo oil you can get at Wally World. Some of that stuff will eat the paint right off the inside of the trans and rear-end cases and then you'll definitely have sump-screen plugged - with paint.
