Good Morning Brad, I tend to agree with Rav there, I also suspect a fuel flow problem, maybe in the tanks outlet area,,,,, or something metal (broken or rusted baffle material???),,,,, ,, or dirt in the tank getting in the outlet area,,,,, ,,,, or too low float level,,,,, ,, or a restriction in the needle n seat,,,,, , or a cap not venting,,,,, or carb baffle plugged maybe ????? heres a few things I would look at: First, make sure the gas cap is venting so shes not air locking. I had a tractor starve for fuel once and the cap was sealed tight was the reason. You might also check the carbs baffle isnt clogged up so air can enter. 1) With the gas on at the sediment bowl or any shut offs, open the carbs lower drain cock/plug and let it flow a minute or 2 to be safe and see if that 1/16 inch stream flows continuous???? 2) If not, remove the gas line from the carb and see if a good strong steady stream the size of the lines inside diameter flows continuous. 3) If not, remove the glass sediment bowl and see how well gas enters the top to fill the bowl area. If shes not strong n steady there, dirt or rust etc may be inside the tank or inlet pipe area and she needs cleaned n purged. 4) If she flows well out the line to the carb but not out the bottom per test 1 above long enough, I would first remove the carb inlet strainers side drain and see if you can clean out any rust or crud..... ..... . If that dont help, I would remove the side inlet strainers top nut n cap(may need new gasket) and clean that all out..... .... If that dont help, I would remove the carbs lower bowl and clean and check the needle n seat area and the float level. Dont loose the lil spring in the bottom. OTHER THINGS TO LOOK AT: Have you adjusted the top load needle settings lately????? Have you removed te air cleaners lower bowl to make sure its clean and NOT have any water??? DOES CHOKING SOME get her back up n running????? ????? If so, there may be some other internal carb restrictions, let us know if you need any carb cleanign tips!!!!! !!! There could be some ignition problem, but it sounds more like fuel starvation for now, so I wont talk spark unless we need it later. I think maybe the float could be low, or a needle n seat restriction, or a tank outlet area or sediemnt bowl restriction, or a clogged cap or baffle, or something like dirt or metal (baffle broken) in the tank restrictign fuel flow for now. Post back your findings or any questions or e mail me at [email protected]. Let us know, Good Luck n God Bless ya Brad. John T
