3020 Vapor Lock
Randy G A
06-08-2005 19:45:10
Is there an easy fix to a 3020 that vapor locks?
Mike M
06-09-2005 07:26:14
 Re: 3020 Vapor Lock in reply to Randy G A, 06-08-2005 19:45:10
Try a new lift pump.
RalphinWI
06-08-2005 21:55:10
The first step should be to make sure that you empty the fuel storage barrel spring and fall and get a fresh fill of summer and winter blended fuel respectively.
msb
06-08-2005 20:09:12
Way back in the days when Wisconsin engines were used on balers and combines,people either clamped clothespins on the gas line or wrapped the gas line with aluminim foil.Vapor lock on those engines drove people nuts.I knew of some who poured cold water on the gas lines to get them restarted after noontime dinner.
