730 DIESEL .......CLOCKWISE OR COUNTER CLOCKWISE
Scotty
06-08-2005 18:47:12
I HAVE A 730 DIESEL THAT I'M TRYING TO BRING BACK TO LIFE. THE ENGINE WAS STUCK BUT NOT BAD, WAS ABLE TO GET THE ENGINE TURN BY SOAKING AND PRYING BACK AND FORTH ON THE FLYWHEEL . HAD ONE STUCK VALUE BUT GOT THAT GOING. SO NOW I'M TO THE 24 VOLT ELECTRIC STARTER AND I'VE GOT THAT SPINNING NOW BUT I WANT TO BE SURE IN THE RIGHT DIRECTION. IF YOUR LOOKING AT THE FLYWHEEL WITH THE STARTER TURNING THE FLYWHEEL, WHICH WAY SHOULD IT BE TURNING ? THANKS FOR YOUR TIME AND HELP..... ..SCOTTY
billde
06-08-2005 20:16:15
 Re: 730 DIESEL .......CLOCKWISE OR COUNTER CLOCKW in reply to Scotty , 06-08-2005 18:47:12
Scotty, looking at the flywheel the flywheel turns CCW. The starter of course would be turning CW viewed from the bendix end.
Duane(Pa)
06-08-2005 19:12:56
The nice thing about starters is that they turn the same direction regardless of polarity. Doesn't matter how you hook up the battery
Bob
06-08-2005 20:25:55
 Re: 730 DIESEL .......CLOCKWISE OR COUNTER CLOCKW in reply to Duane(Pa), 06-08-2005 19:12:56
That statement DOES apply to this tractor, at least to the original starter, but nowadays, there ARE permanent magnet field starters out there, for certain applications, and those DO reverse with a reversal of the battery polarity.
Bob
06-08-2005 19:05:55
Looking AT the FLYWHEEL, it will turn top towards the front of the tractor, or CCW.
Even if the starter were to turn the wrong direction because of switched electrical connections inside the starter, it would NOT turn the engine the wrong way, because the starter drive (Bendix) contains a one-way clutch. In that case, the starter drive would just "slip".
CFWelles
06-09-2005 03:51:24
 Re: 730 DIESEL .......CLOCKWISE OR COUNTER CLOCKW in reply to Bob, 06-08-2005 19:05:55
While you are at it, I have a 730D ES that is not charging and is hooked up with battery positive to the positive starter terminal. I have a 2920 (?) Deere electrical systems manual and I believe it shows the positive battery terminal hooked up to the ground lug on the starter. I guess this doesn't matter at all because I know the 24V system is totally isolated fromt the tractor frame. Am bring this up because I want to wire the tractor back up exactly according to the electrical circuit shown for my tractor in this old manual. Do any of you know for sure that this schematic is 100% correct? Looked at some old posts by Clooney and he warned that Deere had mistakes on some of these circuit diagrams. I can't do much harm, I guess, as the generator is not charging now. I want to get this right. For starters (honest, I didn't intend the pun) do you know if the Starter is supposed to be hooked positive starter terminal to neg battery post? That is what the manual shows.
720Deere
06-09-2005 08:20:33
 Re: 730 DIESEL .......CLOCKWISE OR COUNTER CLOCKW in reply to CFWelles, 06-09-2005 03:51:24
Charlie,
Your positive cable should be hooked to the starter terminal closest to the flywheel on that 730. I just went through all that with the 720 electric start.
CFWelles
06-09-2005 15:27:45
 Re: 730 DIESEL .......CLOCKWISE OR COUNTER CLOCKW in reply to 720Deere, 06-09-2005 08:20:33
Thanks 720. That is the way the Deere Electrical systems manual shows hookup. Presently my tractor is hooked up just the opposite. I am going to wire up the whole circuit in the manner that the electrical systems manual shows for the 24 volt electric start.
720Deere
06-09-2005 16:39:08
 Re: 730 DIESEL .......CLOCKWISE OR COUNTER CLOCKW in reply to CFWelles, 06-09-2005 15:27:45
If you get in a bind, go over to Johnnypopper and look for Jim Guarino, Agri-Services. He makes great wiring harnesses and is very helpful. He helped me with a problem or two before.
CFWelles
06-10-2005 03:48:43
 Re: 730 DIESEL .......CLOCKWISE OR COUNTER CLOCKW in reply to 720Deere, 06-09-2005 16:39:08
Thanks 720. Appreciate the help again! I picked up a spare 24V generator off an Ebay stripper and am going to have a very good repair shop nearby check it out. Generator is only device I have a question on. My wiring is really cobbled on this tractor and think I better bite the bullet and get one from Agri Services. Have read here before that their wiring harnesses are the best bet today. Want to add flat top fenders to my tractor and have everything to do this, but the wiring. Also know that the switch for the four light electric fender configuration will be different from my tractor's switch as there is a field and highway lighting arrangement for the flat top configuration with the four lights. I will contact him as you suggest. Looks like he is best bet. BTW Glenn from Texas was really helpful to me commenting on a switch question I had earlier. He found out that the SWITCH OEM WILL STILL MANUFACTURE THE FOUR LIGHT SWITCH MODEL IF THEY HAVE A MINIMUM ORDER FOR 250 SWITCHES. MAYBE SOMEONE SHOULD TAKE THEM UP ON THIS. BET THERE WOULD BE 250 OUT THERE WHO WOULD BUY ONE OF THESE SWITCHES. I'd take two so that leaves 248. Charlie
