4430 Tech manual, which one?
Gaplowboy
06-08-2005 18:31:49
Hi, I was wandering which John Deere Tech Manual do I need for my 1975 4430? I've seen a TM 1172, and I've seen a TM 1057. Both said 4430, now please explain the difference?
Thanks in advance; Gaplowboy
G/MAN - TM-1172...
06-09-2005 13:42:41
 Re: 4430 Tech manual, which one? in reply to Gaplowboy, 06-08-2005 18:31:49
Go with TM-1172 if you're going to purchase a manual. It covers both sides of the serial-number break at 52148, and also covers the 4630. Much more bang for the buck in that one.
Gaplowboy
06-09-2005 18:54:48
 Re: 4430 Tech manual, which one? in reply to G/MAN - TM-1172..., 06-09-2005 13:42:41
Thanks G/Man! I'll watch e-bay for a TM1172!
Have a nice day! Gaplowboy
G/MAN
06-09-2005 13:38:30
I'll have to look at our manuals for sure, but as Bob said, there are different manuals according to the serial-number break. There were some changes made to various components during production, such as the steering system, rockshaft valve, etc. BUT, the later manual should also cover the earlier tractors, as I was using a later manual while doing some hydraulic work on an early tractor the other day, and it showed the repair procedures for the early tractors, too. I'll check the manuals and post back.
Bob
06-08-2005 19:09:17
What is your serial number? TM 1057 is for serial numbers up through #033108.
The TM 1172 is for serial numbers higher than that.
Gaplowboy
06-09-2005 18:51:39
 Re: 4430 Tech manual, which one? in reply to Bob, 06-08-2005 19:09:17
Thanks Bob! Now that you say that,I thought I remembered it that way, but wasn't sure.
Thanks; Gaplowboy
