Best Method For Manifold Removal On Early JD60?
StuckRusty
06-08-2005 14:55:21
The four bolts are stuck and the bolt heads are stripped so I will have to torch them off and lift up the manifold. Of course I can't do that with the water outlet and fan shaft in the way. Removing the fan shaft involves removing the governor/pump assembly. The service manual says to remove the cylinder head. What have you found to be best, remove the head or remove the water outlet and fan shaft?
Tom nj
06-08-2005 19:30:12
 Re: Best Method For Manifold Removal On Early JD60 in reply to StuckRusty, 06-08-2005 14:55:21
I just replaced the exhaust manifold on my 1955 JD 60. I was able to remove 2 bolts and broke 2 bolts. I was able to get the manifolds off without touching the fan shaft or the water pipe, it was tight though..... 1 bolt stub about 1 inch long I was able to remove with an extractor, the other about1/2 an inch long I had to weld a nut on to remove it. The trickest part was to get the gaskets in the correct location for the new manifold.
Mike M
06-08-2005 16:37:53
I'm with FIT on this one. I'd pull the head. It has probabaly been on there a long time and a valve job may be needed anyhow. Plus I set that head up on a milling machine table drill out the broken bolts with an end mill then run a flycutter accross the gasket surface truing it up as they always seem to erode away on the Right side.Sometimes if eroded away bad I build them up with weld first. Ni rod works well.
F-I-T
06-08-2005 16:46:04
 Re: Best Method For Manifold Removal On Early JD60 in reply to Mike M, 06-08-2005 16:37:53
Mike:
Have you tried Muggy Weld? It really goes easy and it machines nice, too. Kind of pricey, but they don't give away Nirod either.
Frank
Mike M
06-09-2005 04:54:00
 Re: Best Method For Manifold Removal On Early JD60 in reply to F-I-T, 06-08-2005 16:46:04
I have seen that link before and that is really pricey. I have used some Certaium (sp?) rods before and they were really pricey,but you could sure tell the difference. I picked up a few small packs of lincoln ni-rods,machineable and non -machineable a few years back on a clearance rack at a Farm & Fleet super cheap ! Still have some left as I don't weld much.
720Deere
06-08-2005 15:34:47
Although I have never attempted to remove a rusty gasser manifold, I would tend to want to remove the head. It's heavier, but not so much of a PIA as the fan shaft, etc. I have often thought that the best method of removing those seized bolts would be to torch or cut the head off and first remove the manifold. It is inevitable that more than one bolt will want to break off and at least with the manifold off you have access to heat the bolts first and try to soak some snake oil into them.
I would weld a nut onto the remaining bolt down close to the head and try a few heat/cool cycles before torquing on those bolts. That should make removal much easier than twisting one off and having to drill it out of the head. The big thing to remember is patience. Whenever you deal with seized fasteners like those, patience is your best friend. If you get in a hurry, it will end up taking you 3 times as long with less desirable results.
F-I-T
06-08-2005 15:18:27
My favorite method is to remove the head. On a late "A", you could slide it forward and then twist it and drop it out the bottom, but on a '60, I believe it will lift out and over the frame rail on the right side. Either way, it will involve removing the least number of fasteners, plus it gives you a look inside at the valves for the price of a head gasket. A few more bolts and a set of rings and some honing, and while it's not a re-bore job, it's nicely refreshed compression.
My $.02
Frank
StuckRusty
06-08-2005 18:22:14
 Re: Best Method For Manifold Removal On Early JD60 in reply to F-I-T, 06-08-2005 15:18:27
I guess head removal sounds like the best way. It's a shame because the engine supposedly had been overhauled and it runs great. On the other hand, I would like to install a thermostat in the radiator return pipe instead of finding and buying a working shutter/control bellows. Decisions, decisions, oh my!
