4010 inj. pump
kwgray
06-08-2005 04:59:24
I installed a rebuilt injector pump on a 1961 4010. I tried to set it at 14� BTDC but it physically wouldn"t let me set it there. It is at TDC and it runs like a champ. nothing else was apart on the tractor when I did this - the pump was just shot. I don"t plan on changing anything as the old saying goes if it ain"t broke... I thought maybe you folks have seen this situation before.
hogman_2002
06-09-2005 07:02:09
 Re: 4010 inj. pump in reply to kwgray, 06-08-2005 04:59:24
You should have a pump without the fuel advance. If everything in the pump was built to spec. it should be set at 14 degrees BTDC. Although you say it runs like a champ at TDC, I'd say leave it if it doesn't smoke and it starts easily and you're happy with it.
twopop
06-08-2005 05:41:35
when the 4020s came out,they were set a tdc.the timing mark is set by there rebuild shop.even tho the marks are set at tdc,the pump is set to fire according to jd specs.someone probably set the pump for a 4020.or you just have a 4020 pump.
msb
06-08-2005 20:00:11
 Re: 4010 inj. pump in reply to twopop, 06-08-2005 05:41:35
LET ER RIP!Leave it a TDC.Sounds like someone installed a 4020 govenor weight retainer in the pump or etched the timing mark as if it were a 4020.They should have changes the model number on the serial number plate to reflect the change.DBG 631 3AJ ?
kwgray
06-09-2005 06:05:09
 Re: 4010 inj. pump in reply to msb, 06-08-2005 20:00:11
Thank guys for your responses. I knew there was an answer out there. I'll check the numbers on the pump.
