Head Scratcher
Gary north of S
06-07-2005 20:48:05
On my "M" fan assembly, there is a hole in the shaft for a cotter pin. Both in my new assembly and the old one. It's also depicted in the parts manual. What possible purpose does the cotter pin have; it doesn't engagage anything or stop anything from turning that I can see. Any ideas?
Thanks in advance.
Maark
06-08-2005 06:27:22
 Re: Head Scratcher in reply to Gary north of Spokane, 06-07-2005 20:48:05
It keeps the shaft from turning when adjusting the belt tension. There isn't enough room for extra hands when prying up on the shaft and tightening the nut.
leon
06-08-2005 06:24:14
ON THE MT, THUS I PRESUME ON THE M, THERE IS AN OIL HOLE IN THE FAN HUB USED FOR OILING THE FAN BEARING. IS THAT WHAT YOU'RE SEEING?
06-08-2005 08:28:46
 Re: Head Scratcher in reply to leon, 06-08-2005 06:24:14
Nope. The hole is drilled thru the shaft that remains stationary as the hub revolves around it. I think mebbe Maark has the correct answer. Thanks, Maark.
