50 cylinder head
Ben Crafton
06-07-2005 19:49:10
Just wondering how much can safely be planed from
a stock JD 50 cylinder head. I have had several people tell me they took .120" with no problems. Is this true?
buickanddeere
06-08-2005 08:29:36
 Re: 50 cylinder head in reply to Ben Crafton, 06-07-2005 19:49:10
Yes but..... ..... . Those push rods are going to start looking too long and the valve lash adjustment may max out. A set of 50 LP or the even higher compression 520/530 LP pistons are not that expensive. That 50 will be due for at least a set of rings. May as well do them when in this far. A cam from Roberts will as much or more power than cutting the head. Cleaning up those ports, relieving some of the eyebrow and a three angle valve job will be worth just as much HP too. The dry airfilter mod is cheap HP.
