Choke the early D with a 3rd hand?
Loren in Iowa
06-07-2005 19:10:06
How do you keep the spring loaded choke closed on the DLTX3 carb, on the early "D", when cranking the flywheel? Did the old farmers have three hands? I know you can't spin that big flywheel, with one hand, and the choke opens, as soon as you let go of it. I'm baffled.
Easydoesit
06-08-2005 10:13:43
 Re: Choke the early D with a 3rd hand? in reply to Loren in Iowa, 06-07-2005 19:10:06
Loren, On my '25 spoker I fill the priming cups twice (equivalent), turn the gas on until it shows gas between the carb and the intake, set the mag and roll the flywheel. It starts--no choke--easy
Mike M
06-08-2005 05:19:40
Had a 1927 D once and I made a piece of wire to hook in the choke lever and hooked it back over something close by ? Worked good as it started fairly good. I just always keep that piece of wire in the tool box on the tractor.
WeirdDeere
06-07-2005 23:32:40
I agree with Duane, use baling wire!!
We use the priming cups AND the choke to get the '28 running. Strange that the Operators manual doesn't mention using them?
Brandon
Duane Larson
06-07-2005 21:47:21
Loren,
Well, you have raised a very good question that several of us have pondered over the years. The Instructions and Parts Lists from 1925 at least through 1929 make absolutely no mention of any use of a choke during starting. They instruct how to set the carb, open the priming cups and prime, etc., but do not mention using a choke.
One wonders if Marvel Schebler just decided every carburetor needed a choke and so they put one on. It was rather common to find the D's using DLTX3 carbs with a wire hooked to the choke and lots of bends in the far end of the wire where it had been wound around stuff to hold it closed against the spring.
Perhaps someone has an explanation regarding choke usage. By the time the DLTX6 came in 1931, the instructions included use of a choke along with the priming cups.
RK in Iowa
06-08-2005 10:13:56
 Re: Choke the early D with a 3rd hand? in reply to Duane Larson, 06-07-2005 21:47:21
Duane, doesn"t it mention adjusting the carb to enrich fuel ,then readjusting after running. RK
Glen in TX
06-08-2005 13:37:23
 Re: Choke the early D with a 3rd hand? in reply to RK in Iowa, 06-08-2005 10:13:56
Yes, it mentions to open the load needle more when starting in cold weather before starting or when loading heavy and then closing it back after warming up. Dir. 108 only mentions opening the choke after engine has fired and tells nothing about how to hold it closed. The wire and priming cups are a must have.
Duane Larson
06-08-2005 13:34:42
RK,
My early D Instructions and Parts Lists are in the house so I'm going from memory(??), but as I recall it gives instructions about reseting the load and idle needles for starting. The choke is not mentioned. And I've always wondered how JD expected one to hold the choke closed on a D - most folks can't spin the flywheel with one hand. They could have offered a wire or something to close the choke - but nothing was offered that I have seen. Wierd.
Glen in TX
06-08-2005 13:43:46
 Re: Choke the early D with a 3rd hand? in reply to Duane Larson, 06-08-2005 13:34:42
Duane, I just looked in my Dir. 108 for the early Ds and like you said it tells nothing about how to close the choke and only mentions putting some fresh gas in priming cups if cold weather or starting is difficult. It did tell about opening the load needle some for starting too. That's why I liked leaving the DLTX-63 on the 28 D we had and it ran great too with those .045 OS high altitude pistons in it.
Duane Larson
06-08-2005 21:14:44
 Re: Choke the early D with a 3rd hand? in reply to Glen in TX, 06-08-2005 13:43:46
Glen,
The first D Instruction and Parts List (IPL) was Dir No. 3, 1924 to at least 1928, then Dir No. 76, 1932, then Dir No. 108 in 1934 as I recall, and by that time the DLTX 6 (with the usual hand choke) was in use. My comments were aimed particularly at info in Dir. No. 3, through 1928, before the D used a carb with a "functional" choke. I imagine it must have been messy carrying along a can of gas just for priming, and with the choke just setting there and most every owner probably had a car with a choke, so it got used rather than the priming cups.
I can easily see the advantage of putting a DLTX63 (with the usual hand choke) on your early D! Those pistons must have given it a bark.
Glen in TX
06-08-2005 22:04:46
 Re: Choke the early D with a 3rd hand? in reply to Duane Larson, 06-08-2005 21:14:44
Duane, That's interesting to know about the other directories for the early D. Mine are not originals and the Dir. 108 I have has the green cover showing for #30,400 to 119099. It is a copy I got from JD in the late 70s. Yeah, we have found Maytag fuel mixing cans in D tool boxes before used for the primers.
