Leaky Fuel Lines
Joe Lee
06-07-2005 13:54:36
I've got a '35 A, '50 B, and a Farmall F-12. It seems like I'm always tweaking a leaky gas line fitting. Is there some sure-fire way (short of replacing the line) that I can try to stop the leak?
Joe Lee
msb
06-07-2005 19:46:23
 Re: Leaky Fuel Lines in reply to Joe Lee, 06-07-2005 13:54:36
Have a Ford NAA that an old Kentucky boy had.He "fixed" the leaky line on it by wrapping ordinary string on the line just in front of the fitting so the fitting would have more compression.He also used pliers on all fuel lines too.Man,I couldn't live like that.lol,bob
John T
06-07-2005 14:24:19
Joe, Im definitely with Glen on this one. Those original JD and others steel lines have something like a 1/4 or 5/16 line but that oversize more like 5/16 or 3/8 (a size bigger) swell on the end and that size n curve need to match the carb inlet and sediment bowl or brass valve etc. outlet to seal correct. If they are the correct size n circle n angle etc. thats what seals AND NOT MUCH PRESSURE OR NUT TIGHTNESS IS REQUIRED. One problem may be the original fittings have been replaced with assorted automotive brass ferruled or compression fittings which might take the same nut but they just dont match up corect for a good seal.
I HATE LEAKS especially on new paint, I guess you might try some sealants rated for gasoline which might hold, but remember its usually NOT the threads that are supposed to seal its that junction is supposed to mate.
Thats all I have to say (or know) about that.
John T
Glen in TX
06-07-2005 14:13:05
Several online parts suppliers now have original type new fittings for the tube ends and nuts and other fittings. Otherwise you have to go with ferrule fittings or hose.
