2240 JD Power???
Ponchobro
06-07-2005 02:37:31
Hello, I am looking at a 2240 John Deere. Does this tractor have the power to run a 4'x5' round baler??? Were these good tractor's. Thanks
PJBROWN
06-07-2005 04:16:46
 Re: 2240 JD Power??? in reply to Ponchobro, 06-07-2005 02:37:31
It should have the power to run 4'x5'. but do you have the weight ???? Are all your fields level ??? If they are hilly you might want a heavier tractor..... just so the baler will not be pushing you.
Indydirtfarmer
06-07-2005 02:57:34
50 HP (PTO)
Depends on WHAT BALER...(brand?)
Good tractor. Watch anti-freeze PH level. Engine proned to wet-sleeve pitting (like most wet sleeve diesels) Make certain NO ONE has put 90 wt. gear oil in rear end/hydraulic system. That ruins the brakes, which in turn plugs up the hydraulic system.
Ponchobro
06-07-2005 09:12:07
 Re: 2240 JD Power??? in reply to Indydirtfarmer, 06-07-2005 02:57:34
The baler is a hesston 5545 rounder. Thanks
