730D throttle
F-I-T
06-06-2005 17:00:29
Ok...the only other thing is the other end. Could be possible that the governor arm jumped out of the guide yoke.
If you operate the throttle lever, do you get normal operation from the governor side? I expect not. You can take that elbow shaped casting off the left side and re-set that pivot arm into the governor slot. I've heard that they can pop out of position. Then you can readjust the eccentric that it pivots on so that it has no slop.
