Instant water in 1020 Oil
GOT
06-06-2005 16:02:45
Driving along in 4th and poof...desiel engine stops like the key was turned off. Lots of water moved into oil sump. After cooling it started but shut it right off, changed oil and added water. Started right up and drove into shed where once again gallon of water in oil. Pulled head, can find no easy visible damage to gasket, no cracks in head. Maybe warped? Believe engine just got too hot to start with as it may have been low on water. 8,000 hours and first problem... Speculations??
mowr
06-06-2005 20:19:49
 Re: Instant water in 1020 Oil in reply to GOT, 06-06-2005 16:02:45
If it's dumping that fast, it should be easy to see where it's coming from by pulling the pan and having someone pour water into the water jacket above while you watch the innards from below.
105Diesel
06-06-2005 17:36:03
Just offhand, I'd bet it's got what we used to call "Dubuque Disease"---in other words, one or more of the O-rings on the bottom of the cylinder liners has blown, either that or a hole in a sleeve from pitting and erosion. Either way, it's time for a complete overhaul, or new sleeves and pistons at the very least.
