2940 hydraliics
quinten
06-06-2005 16:00:13
I have a farm hand loader on this tractor. when using the loader it seems to lose pressure or something because as the day goes on you have to keep raising the rpms to eliminate the chatter in the loader buy the end of the day the tractor is operating at 1500 to 1800 rpms. The local shop tells me that is a john deere for you. I dont buy it. Any suggestions would be apreciated. dose the tractor have a hydro filter? and if where is it located. thanks
Tx Jim
06-07-2005 04:44:16
 Re: 2940 hydraliics in reply to quinten, 06-06-2005 16:00:13
The hyd filter is located under the RH footrest and there is also a sump screen that needs to be cleaned.Filter is in a rd. canister pointed down,you can route return oil from loader valve back to filter canister to aid loader operation.Also you can adjust stand-by pressure to 2400psi. An operators manual would be a good investment.Tx Jim
PJBrown
06-06-2005 18:19:17
That's a Mannheim John Deere for you !!! We have a 2030,2840,and a 2755 they all do the same thing. They can't return the oil quick enough and the pumps starve for oil. The John Deeres have a closed-center hydraulic system..... A Open hydraulic system will not "chatter" ,but sometimes they work a little slower. I was told that some of the brand new John Deere's have open hydraulics. I think the 6603 has a open system. I have been told by a number of people that the Waterloo built John Deere will not starve for oil like the Mannheim Deere's.
cannonball
06-07-2005 09:40:44
 Re: 2940 hydraliics in reply to PJBrown, 06-06-2005 18:19:17
we have a 2840 and it does not do that ...if plumed in right and screen and filter clean they will work!! if not you have internal leak.. we had a line crack in 2840 put in new line works as good as the others...have nice day may god bless
quinten
06-07-2005 12:33:23
 Re: 2940 hydraliics in reply to cannonball, 06-07-2005 09:40:44
Cannonball how should the loader be plumed? If I remember I think it just has two lines comming off of the trans housing up to the control valves. I will look tonight and see for sure. If you could tell me how it should be plumed correctly I would appreciate it. Thanks
cannonball
06-08-2005 18:56:23
 Re: 2940 hydraliics in reply to quinten, 06-07-2005 12:33:23
you need return going back into filter cover..high pressure will come of behind pressure control valve....if this is done then you can have leak in pto, hilo..line going to front pump..a 2840 feeds pto then up to hilo and front hilo asteel line inside cracks or breaks it feel front pump..ours chattered till it broke then it quit...i have jacks made for the smaller jds and i roll front part of tractor...replaced this line by myself in less than 8 hours...have nice day may god bless
