Another 2 cyl injector question
MN 730
06-05-2005 19:55:09
I'm still trying to pinpoint my fuel leak and noticed fluid leaking from around the rack shafts on the pumps when the engine is running. Is this where the lube oil normally exits the pumps or is this the source of my fuel leak?
720Deere
06-06-2005 04:29:15
 Re: Another 2 cyl injector question in reply to MN 730, 06-05-2005 19:55:09
I don't really know that there is any oil "coming out of the injector", but there is enough oil that splashes around in there that it can be confusing. If you had a fuel leak in that area, it would be high pressure most likely and would create a very clean spot wherever it was spraying. Anytime that I have looked in the injector compartment on my 720, I get paranoid for weeks about what all that mess is splashing around in there.
Are you gaining oil level in the crankcase? If you are there is a good chance that your leak is the fuel transfer pump seals rather than the injectors or pumps or fuel lines.
msb
06-05-2005 20:16:45
There are only two places that normally leak on those racks.One is the gasket that is between the individual pumps and the casting and they rarely ever leak.The most likely place is the copper gasket between the delivery valve holder and the nozzle barrel end cap .It is a copper gasket and will develope erosion cracks after a few years of service due to the high pressure involved and the vibration of the injector itself.It takes a special puller to remove the delivery valve holder after the barrel end is removed.Then to properly replace the gasket, the delivery valve holder and the pump barrel surfaces need to be lapped or chances are the new gasket will leak.If you really want the engine to run smoothly then the rack needs to be calibrated on a test stand so both pumps are delivering the same amount of fuel.
MN 730
06-05-2005 20:23:37
 Re: Another 2 cyl injector question in reply to msb, 06-05-2005 20:16:45
So I"m seeing lube oil leaking out at the racks or what?? Where does the lube oil exit the pumps?
Kevin L.
06-05-2005 21:00:34
 Re: Another 2 cyl injector question in reply to MN 730, 06-05-2005 20:23:37
don't think there's any oil traveling thru the injector pump rack, if you got a leak in this area I'm thinking it's more likely to be diesel fuel and your crankcase oil level will be increase.
mike brown
06-06-2005 04:42:43
 Re: Another 2 cyl injector question in reply to Kevin L., 06-05-2005 21:00:34
There is no crank case oil going through the injector pumps. There is cc oil on the camshaft lobes and the cam followers and those little short push rods that run the pumps so oil gets up aound the pumps but internally they are lubricated by diesel fuel.
MN 730
06-06-2005 14:46:59
 Re: Another 2 cyl injector question in reply to mike brown, 06-06-2005 04:42:43
There is lube oil supplied to the pump rail. That is what that short tube in the middle of the rail is for.It goes straight down into an oil passage and is sealed by an O ring on each end of the tube. So, where does this oil go once it is in the rail????
Kevin L.
06-07-2005 11:15:15
 Re: Another 2 cyl injector question in reply to MN 730, 06-06-2005 14:46:59
Now I'm puzzled, the parts break down lists shows an oil inlet tube. Now makes me wonder if they do feed oil to the rack and maybe the pumps. If oil is in the area of the pumps if can return to the crankcase by running over into the valve cover side or the camshaft side. But if oil is supplied the rack then this may explain why the rack on my 720D is sludgish and I just blamed it on the varnish and sitting up.
mike brown
06-06-2005 16:54:16
You got me. I've had them out before and don't remember any tube but it's been a few years.
