3020 Little white thing
Playfarmer
06-05-2005 18:53:15
I recently bought a early model 3020 sr. #55563 and today I was messing with the hydraulic coupler and somehow managed to push the coupler in so I got my hook out and pulled it back when I did a o-ring fell out and this little white plastic coil. I can see that the other side has one also so my assumption was that it is supposed to hold the o-ring in but I am just guessing, anyway I have not got it back in and was wondering if I really need it and how to put it back if I do. Thanks in advance Playfarmer
matthies
06-05-2005 19:38:21
 Re: 3020 Little white thing in reply to Playfarmer, 06-05-2005 18:53:15
Yes it does help support and seal the quad rubber ring. A right angle/90 degree oring pick and some patience helps. Start with one end and push the quad ring back with the pick while you work the white teflon ring in with your finger. Good luck
thurlow
06-05-2005 19:37:31
Back-up ring; goes behind the o-ring. You need it in there since it was there, although there are some not-a-true-o-ring that don't use them. Might I suggest that you reach around behind the coupler and push it out rather than using a hook.
Playfarmer
06-06-2005 04:57:14
 Re: 3020 Little white thing in reply to thurlow, 06-05-2005 19:37:31
Thanks Guys I'll try working on it when I get home from work. I did not know that I could push it out from the backside. That is what is so great about this forum everybody gives such good tips. Thanks again!!!!! !!!!!
