Ign coil resistor? Clooney
JDG
02-24-2004 19:29:37
How can you tell if a coil is a internal or external resister if it doesn't say on coil?
Clooney
03-07-2004 08:20:45
 Re: Ign coil resistor? Clooney in reply to JDG, 02-24-2004 19:29:37
JDG, sure there is..
~I presume we are talking about a 12 volt tractor here.. If so the easy way is to just idle the tractor for about 15-20 minutes.. If the coil is extremely hot to the touch it is probably an non resisted 6 volt coil running at 12 volts.
~Another way is to let the coil cool off, then use a simple ohm meter to measure the resistance between the two little [+] & [-] terminals.. A 6 volt coil will be around 1.5 ohms give or take a little & will need a ballast resistor installed in it's power feed wire of around 1.5 to 2 ohms to function properly on a 12 volt system.. An internally resisted 12 volt coil will probably measure between 2.75 & 3.5 ohms depending on it's temperature & internal resistor package..
~You can't just measure the voltage on the distributor side of the coil as that will be 12 volts on either a 6 or 12 volt coil with the points open & around 0 volts on either a 6 or 12 volt coil with the points closed.. You would have to measure it with the engine running to get a meaningful measurement & the voltage would then depend on engine RPM [points closed dwell time] & the meter you used.. Most cheap meters won�t capture the pulsed voltage on the distributor side of the coil & you would need an expensive meter or a scope to get a proper reading.
[email protected]
John T
02-25-2004 06:32:06
Good Morning JD, Im just getting here, I havent seen the good clooney man yet, but will toss out another opinion until he can furnish his, the more the merrier and were all here to help the best we can.
If the coil is not labeled, I agree with Duane that checking its total primary resistance, measured between its lil + and - terminals, may provide whether or not its internally resisted like many 12 volt coils.
1) If the DC resistance is around 1.3 to maybe 1.7 ohms, its probalby a 6 volt NOT internally resisted coil.
2) If the DC resistance is around 2.5 to maybe a tad over 3 ohms, its probably a 12 volt internal resistor coil.
3) If the DC resistance is in the 2 ohm range, I cant say for sure what the heck it is.
The reasons are that to protect the ignition points from premature burn up, the current passign through and switched by them was limited to the vicinity of around 4 amps. Therefore, the total primary ignition circuits (coil + any internal or external ballast) would have to be around 1.5 ohms on a 6 or 3 ohms on a 12 v system, but different coils and points etc. can have variations, of course.
Heres a few other questions which may help us help you..... ...
What tractor is this on??? What voltage is the battery???? If after running, is the coil warm,,,,, orrrrr rrr so hot you can barely touch it????? ? if its extremely hot, it may be a 6 volt coil on a 12 volt system intended for a ballast, in which case too hot and excess curent may harm the coil and/or cause premature point burn up!!!!! !!!!! !!!!!
I have some coil articles somewhere in my puter, post back or e mail me at [email protected] with any questions. It will be good to hear some other opinions on how to tell if the coil is internally ballasted, but I hope this helps in the meantime.
Let us all know.
Good luck n God Bless ya JD
John T Nordshoff in Indiana
OldFart
02-24-2004 21:20:03
Check The Voltage On The Points Side of The Coil,
If a 12 Volts System Has More Then 6 Volts ?. It's not Internal Resisted, More then 6 Volts will (Cook) Your Points.
Duane Larson
02-24-2004 20:34:42
JDG,
While I'm sure not Mr. Clooney, I'll take a shot at it since I'm still up. If you take a good ohmmeter and measure the primary resistance across the coil and get about 3 ohms, the coil has an internal resistor. If you get about 1.5 ohms, the coil has no internal resistor. Depending on your measuring equipment, be sure to zero the meter with the leads shorted together, as it is tricky to measure low resistances.
If you make this measurement and post back with the result, or, if the coil has numbers embossed in the case, post back with the numbers, and we'll try to help further.
I believe Mr. Clooney rises earlier than I do....
JDG
02-25-2004 18:08:44
 Re: Re: Ign coil resistor? Clooney in reply to Duane Larson, 02-24-2004 20:34:42
Duane no # embossed, but has # 505 12V printed on coil. Thanks for other responses. Will try test.
Duane Larson
02-25-2004 20:09:39
 Re: Re: Re: Ign coil resistor? Clooney in reply to JDG, 02-25-2004 18:08:44
JDG,
That is interesting - I sell coils labeled 504 12V, and 505 6V. I am not familiar with your coil, so it will be interesting to see what the primary resistance is.
