Ign coil question? Clooney
JDG
02-24-2004 19:21:16
Is there any way to tell if a coil is a internal or external resistor if it doesn't say on coil?
Clooney
02-25-2004 03:35:51
 Re: Ign coil question? Clooney in reply to JDG, 02-24-2004 19:21:16
JDG, sure there is..
~I presume we are talking about a 12 volt tractor here.. If so the easy way is to just idle the tractor for about 15-20 minutes.. If the coil is extremely hot to the touch it is probably an non resisted 6 volt coil running at 12 volts.
~Another way is to let the coil cool off, then use a simple ohm meter to measure the resistance between the two little [+] & [-] terminals.. A 6 volt coil will be around 1.5 ohms give or take a little & will need a ballast resistor installed in it's power feed wire of around 1.5 to 2 ohms to function properly on a 12 volt system.. An internally resisted 12 volt coil will probably measure between 2.75 & 3.5 ohms depending on it's temperature & internal resistor package..
~You can't just measure the voltage on the distributor side of the coil as that will be 12 volts on either a 6 or 12 volt coil with the points open & around 0 volts on either a 6 or 12 volt coil with the points closed.. You would have to measure it with the engine running to get a meaningful measurement & the voltage would then depend on engine RPM [points closed dwell time] & the meter you used.. Most cheap meters won�t capture the pulsed voltage on the distributor side of the coil & you would need an expensive meter or a scope to get a proper reading.
[email protected]
