520 lift problems
wm morath
06-05-2005 08:00:39
I just hooked up a 3 point plow to the lift on my 520 ,The lift will pick the plow up all the way then it will drop a little and then go back up ,it surges rapidly up and down the system has plenty of fluid any ideas where I should start looking? Also can anyone tell me what a 4 bolt center fill B is worth I am just about finished with it and am thinking about selling it,Serial# 1327.Thanks Bill
ChuckW
06-05-2005 17:34:39
 Re: 520 lift problems in reply to wm morath, 06-05-2005 08:00:39
Be sure to note that the 520 has a valve at the center point to provide draft control. If you linkage is not adjusted properly you can get this effect. There are about 4-5 positions for the hookup and you have to have the right lenght adjustment. Be sure to check you manual before you do anything mechanical. If it will lift and hold another item you may just have an adjustment problem.
Guy from Mi
06-05-2005 12:53:28
My 1010 did the same thing.I have 2 check valves on mine, 1 on each side of my hyd cylinder and valve housing. With tractor running and plow surging up and down I could hear the check valve the was purging. I bought some shims for about 25 cents from JD dealer and put 1 or 2 in the check valve were the shims are put in. It's been running great 3yrs later. Mine was very easy to get to and fix. Just drain hyd fluid, unhook snapring, and pull out check valve and put 1 or 2 shims. Hope this helps you.
2 Cylinder
06-05-2005 09:53:21
You"d be better off asking those questions on the John Deere forum, and maybe more likely to get the information your looking for.
2 Cylinder
06-05-2005 09:58:08
 Re: 520 lift problems, my apologies. in reply to 2 Cylinder, 06-05-2005 09:53:21
My apology, we are on the John Deere forum. I need to get my act together
mike brown
06-05-2005 18:54:03
 Re: 520 lift problems, my apologies. in reply to 2 Cylinder, 06-05-2005 09:58:08
My 730D does the same thing. I think it might be oil leaking by the rock shaft piston or the valve allowing it to settle. The position sensor then picks it back up to where it is supposed to be. As for the draft sensing, I think the hole nearest the pivot is least sensative.
With the tractor shut off it will slowly settle to the down position.
