3010 FAN BELT
SKYBOW
02-24-2004 19:00:01
Ran a piece of metal into the rear of the radiator. Cut one of the verticle tubes. I'm taking it to a shop to see if it can be repaired. While I have it out I noticed the fan belt is showing quite a bit of wear. I want to change it too but am not sure how to do it. Any explanation would be appreciated. Thanks
Glenn
02-25-2004 03:52:10
 Re: 3010 FAN BELT in reply to SKYBOW, 02-24-2004 19:00:01
It's very easy.Loosen the generator bolts,no need
to take them all the way out,push the generator toward the engine and slip the belt off.You may have to disconnect the coupling to the front pump
but that is pretty simple also.
SLYBOW
02-29-2004 09:52:49
 Re: Re: 3010 FAN BELT in reply to Glenn, 02-25-2004 03:52:10
Thanks Glenn,
What does the front pump do. Is it hydralic? Are there any springs, bushings , small parts in the coupling that may get lost when I remove it? Do the coupling Bolts need to be torqued after I reinstall the belt and reassemble the coupling?
Thanks again
