First work with my 730D
CFWelles
06-05-2005 04:33:58
Just a followup on a few posts I have made about rebuilding the powershaft assembly on my row crop. Yesterday I hooked the tractor to a big pull behind brush hog and went to work with this tractor for the first time since I bought it last fall. I just love this old 730. With that flywheel and the big power impulses I put the tractor in third gear and could slow it down when I hit a rought spot and ramp it up enough when the going was smooth to stay right in third the whole time. These are one great tractor that Deere built and am just sorry I waited so long to own one. The powershaft foot assembly a clutch worked beautifully once I hooked it up and worked it a few hours. Unit stops with the brush hog on without the brake indicating that the light oil specified leaves very little drag once everything is worked in and adjusted right. Getting this tractor, getting my first totally successful rebuild of a major assembly on it has been one of the most enjoyable experiences I've had in a while. Just wish I had a set of four bottoms to hook to her because listening to that ole gal pull under load is pure symphony. Only time I can enjoy it with the mower is mowing high grass up a pretty good grade. Appreciate the posts I have read since here since I decided to find one of these great old machines. I know I've got to get into the shifting forks,rods,detents because she can get a little messed up from time to time when shifting. Have a question for any experienced folks here on turning a corner. Heard some clatter in the gear box when turning and am assuming this is the gears slapping back and forth when the differential is working on a corner? Is there anything disturbing to you fellows about the clatter I am hearing in a corner? Gears all sound good when pulling and I found nothing really wrong looking in the backside of the gear case when I had the rockshaft housing off to replace the powershaft oil pump seals. Especially, there were no chunks of gears laying anywhere in the bottom of the case.
ChuckW
06-05-2005 06:12:00
 Re: First work with my 730D in reply to CFWelles, 06-05-2005 04:33:58
Glad you really enjoy the old deere but a word recommendation on the drive train. The 2 cylinders do have a trememdous amount of torge, but if you throttle down and allow heavy governor surge you could trash out your transmission and or pto drive train. The surge could damage your transmission drive teeth. Also be sure you have a slip clutch and also an overriding clutch on your drive train to the mower. I always keep the bushog reveved up so it want have to rely on a power surge from the 2 clylinder design engine.
720Deere
06-05-2005 06:36:09
 Re: First work with my 730D in reply to ChuckW, 06-05-2005 06:12:00
ChuckW,
If I remember correctly, Charlies 730 is a diesel. You just don't have the governor surge problems with a diesel like the gas models do.
The overrun clutch is a good idea even with the independent pto. If you ever had to replace that little pto brake in one those tractors, you will appreciate the worth of that overrun clutch. No need to apply all that bush hog momentum to that little brake that just wasn't meant to do that job.
Richlizzy
06-05-2005 06:25:53
I have a John Deere F145 semi mount 4x14 plow that would look good on that tractor. I have used it on my 730D, and it works great. I would be willing to sell it because I no longer have a need for it. Let me have some way to contact you and maybe we can get together.
MSM
06-05-2005 04:47:19
If your bush hog is a pull type,what you may be hearing is driveline chatter caused by the u-joints binding slightly on hard turns. This can be reduced by making sure the driveline is in a straight a line as possible from the tractor to the mower,and the correct height from the drawbar to the pto,as well as the proper distance from the drawbar pin to the end of the pto shaft.
CFWelles
06-05-2005 04:53:39
 Re: First work with my 730D in reply to MSM, 06-05-2005 04:47:19
Thanks. Bet you are right on that. Hadn't thought of that. I am aware that when a standard spider is angled you get uneven output in a revolution which can cause speeding and slowing. That makes sense that this is the cause. Thanks. I AM running a pull type and am considering selling it and buying a 7 or 8 foot three point mounted because it will allow more maneuverability and hense less need to stop and change gears to get a corner or tight spot. I'll have to check how much weight I can hang on the back of the tractor during the transport mode. Thanks again.
720Deere
06-05-2005 06:39:18
 Re: First work with my 730D in reply to CFWelles, 06-05-2005 04:53:39
Charlie,
Do you have your drawbar lined up with the pto shaft? Poor design on the live pto two cylinders. The shaft is not centered on the tractor and you need to swing the drawbar over to line up with it. If your drawbar is still centered, right turns are going to exagerate the powershaft angle and cause you noisy problem.
CFWelles
06-05-2005 12:15:22
 Re: First work with my 730D in reply to 720Deere, 06-05-2005 06:39:18
Thanks 720 and thanks also ChuckW. This is my second draft of this. Too often I forget to click possts twice and end up losing my posts. Yes I did see the offset drawbar position allowed perfect lineup with the offset PTO and did that. The engineers nailed that detail as well on this great tractor. The throttle response is gradual and proportional on my diesel as 720 points out. Haven't noticed any surge. AS far as the overrunning clutch is concerned, that is a great comment and I don 't have one. I understand the point you are making 720. The pto brake is tiny and I just replace it and don't need to do it again. Was quite a job as you say. I am going to look at a new JD three point and will check to see if they ar offered with an overrunning clutch. My old Woods trailer mower doesn't have this feature. Thanks again fellows. Regarding the plow, I would like to take you up on this, but have to first get the field mowing under control before I consider becoming a part time crop man. Too much going on in my life right now for this.
Thanks again fellows, Charlie
720Deere
06-05-2005 14:17:38
 Re: First work with my 730D in reply to CFWelles, 06-05-2005 12:15:22
Charlie,
If the pto joints are what is causing your noise, there may be one other cause that we haven't addressed yet. The length of the drawbar can change the mower/tractor pivot point and thus create higher joint angles. You may want to check into that.
An overrun clutch can be purchased seperately sort of like an adapter that goes on your tractor powershaft. It would certainly go a long way toward saving that pto brake. These tractors were not really designed to handle stopping the high momentum loads that a large mower can put on them. At the very least, you can throttle the tractor down to an idle before you turn the pto off. That will help lessen the amount of momentum that the mower blades force the pto brake to stop.
Good luck with your 730. I know you will enjoy it as much as the rest of nuts do our tractors!
Ed Cooper
06-05-2005 17:19:12
 Re: First work with my 730D in reply to 720Deere, 06-05-2005 14:17:38
I too just got a 730D last fall. I had bought a JD 50 and a 6 foot 3 point hitch brush hog. The 50 would run it, but she was really working hard in 1st. gear. I found this 730D in classified ads. Trade the guy my old B and some cash for it. Runs really great. Handles the 6 foot cutter without any trouble. I can go in 3rd gear on the light stuff, but it cuts much better in 2nd with the pto at 540 rpm. I thought about getting a bigger cutter, however be prepared to pay a lot more money for one.
CFWelles
06-06-2005 16:43:01
 Re: First work with my 730D in reply to Ed Cooper, 06-05-2005 17:19:12
Ed, you must have some heavier mowing than I have. Also, I just mowed here in early June and the growth isn't full yet. Third was fine with my 6 foot. Regarding the three points, the new Deere three point brush hog design has shown up on Ebay a couple of times. Recently there was a nice 7 foot that went for around $1750. They have all been in Arkansas and that is about 1200 miles for me, just too far for a brush hog. You might watch Ebay as these come up there from time to time. Mostly ahve seen 6 foot diameter deere 3 points, some near new. I would like to latch onto a 7 or 8, but I hear you. I would guess that deere wants about $3000 for a 7 foot. I'll keep watching ebay for a 7 that is a little closer.
