2440 problems with shifting and hydralics
RHB
06-03-2005 19:22:26
My 2440 when it works for about an hour the tractor will not go into gear. It has 8 fwd and 4 reverse. It grinds trying to go in gear as if the clutch is still engaged. The tractor also will not lift the implement on the 3 point hitch unless you give it lots of throttle and is very slow then to lift. The steering column is blistering hot also when this happens and the hydralic oil seems to be very hot also. Could these two problems be caused by the same culprit? The tractor sits over night and cools down everything seems to function although the lift jerks a little coming up even cold. Fluid has not long been changed and filter. Need advice. Thanks
RHB
MSM
06-04-2005 04:31:59
 Re: 2440 problems with shifting and hydralics in reply to RHB, 06-03-2005 19:22:26
Sounds like 2 problems. The clutch may have oil on it,causing it to drag when hot. The hydraulic system has an internal leak,causing it to lose function when it warms up.Start the tractor and let it run for 5-10 minites. Listen for any internal hissing or buzzing,feel the hydraulic components(remotes,rockshaft cover near the valve,steering column arond the relief valve in the filter area etc.) If a component gets warm to the touch(warmer than the others) It is leaking internally.The closed center pump on a Deere doesn't pump oil unless it is needed. If there is an internal leak,the component will heat up,if the leak is bad enough,it will lose enough oil to cause problems with the other functions.
Tx Jim
06-04-2005 04:21:19
RHB,on clutch how much free travel does peddle have? On hyd's an internal high pressure leak can cause oil to get hot and hyd's to be sloooow.The steering valve is a good starting place.Heating of hyd. oil is a vicious circle,hotter oil gets the thinner it gets the more it leaks.Tx Jim
