Is the 4030 the best 80 HP JD made???
PJBROWN
06-03-2005 18:57:23
Is the 4030 the best 80 HP JD ever made ??? Or are the 29's..... .2940,2950,and 2955 better ??? And if the the 4030 is better why did Deere stop making a 80 HP row crop ???
JHRanch1
06-05-2005 06:54:02
 Re: Is the 4030 the best 80 HP JD made??? in reply to PJBROWN, 06-03-2005 18:57:23
PJ: We've had 2 4030's over the years 1 synchro, and 1 quad-range both with 148 loaders. We still have the quad, we use it every day in the feedlot, other than charging the A/C occasionaly(prior to converting to R-134) it's been 7,000 hours of trouble free tractor.
Tx Jim
06-04-2005 04:26:48
PJ,from my experience working for a Deere dealer when 4030's,2840's and 2940's were sold the mentioned Dubuque tractors don't start to be in same class with a 4030.Tx Jim
j cook (iowa)
06-04-2005 05:32:18
 Re: Is the 4030 the best 80 HP JD made??? in reply to Tx Jim, 06-04-2005 04:26:48
I think that you will find that the last Dubuque tractors made were either 2440 or 2640 and that the 2840 was a Mannheim tractor. Also, I think that the 4030 only had one other Waterloo built tractor to compete with it---the gasoline 4010 and it might be possible to say that 11 years worth of improvements would make the 4030 better than a 4010 GAS!
Tx Jim
06-05-2005 04:04:05
 Re: Is the 4030 the best 80 HP JD made??? in reply to j cook (iowa), 06-04-2005 05:32:18
j cook,CRS caused me to call the before mention tractors by wrong factory name and I apologize.But whatever factory or country they were built in won't make them as good as a JD 4030. IMHO,Tx Jim
A Deere Guy
06-03-2005 20:00:59
Yes you could say that. The 4030 has somethings most 80 hp tractor dont have today. The 4030 has a Perma-Clutch (wet clutch) The 2940, 2950 and 2955 do not have a wet clutch. Also the 4030 can have a Syncro-Range, Quad-Range, or Creeper transmission.
