3010 466/404 conversion
potentpuller
06-03-2005 18:35:59
I've got a 3010 and would like to try and turn it into a hot farm puller. Will a 466 or 404 block bolt into a 3010 rear end?
If so, how much work is it to get 2 more cylinders to fit? Looking for about 300-400 HP and 4500 RPM. What will need to be done to get the block to take that high rpm?
jd jack
06-06-2005 05:21:32
 Re: 3010 466/404 conversion in reply to potentpuller, 06-03-2005 18:35:59
They will bolt to the rear end. The hood, frame rails and everything else will have to be lengthened to fit the motor in.
stum
06-05-2005 04:57:32
You would probably get the same results with a 6030,and have about 1/4 of the money in it. What you want to do could be done,but it will take alot of adapting,the 3010 won't stand that much horsepower.Getting a 404 or 466 to hold together at 4500 rpm,would probably cost $15-20000,in machine work,balancing,special valve train,head work,pump work and chargers.
potentpuller
06-05-2005 14:29:37
 Re: 3010 466/404 conversion in reply to stum, 06-05-2005 04:57:32
The problem with the 6030 is that it ts way too heavy, plus our club manditates the use of a stock frame. I'm trying to get into 5500# and 6500# hot farm class.
