70 cam side paly spring, and bracket?
ChadS
06-03-2005 08:49:26
Im putting a 70 gas back together, working on installing the crank, the cam has a spring that hold tension against the end of the cam, to hold it in place, is there a cover that is separate from the housing that bolts on, or is it incorparated with a larger cover? I got this 70 in a box,,, or boxes you could say, Im just making sure its all there, or if Im missing parts,,, Thanks for any info! Chad
Mike M
06-03-2005 10:01:50
 Re: 70 cam side paly spring, and bracket? in reply to ChadS, 06-03-2005 08:49:26
The reduction gear cover (large cover on RH side)should have a spot to hold the spring seated in it. PLEASE ! Do yourself a big favor and get a copy of the JD parts catalog before you go any farther. These show all the parts in order,with good pictures,very accurate,and even give the sizes for the hardware.
ChadS
06-03-2005 10:14:00
 Re: 70 cam side paly spring, and bracket? in reply to Mike M, 06-03-2005 10:01:50
Thank you. I do have a parts book for a 60, I havent looked at the cover just yet to know what holds it in place, it just looked like it had a separate plate. I bought a new crank for it, well reconditioned,, the old flywheel had a taper lock system on it rather than the stock nut, will this interchange with the new crank? Chad
Mike M
06-03-2005 10:22:29
 Re: 70 cam side paly spring, and bracket? in reply to ChadS, 06-03-2005 10:14:00
I don't see any reason that the taper lock shouldn't even be better on a good crank spline than a worn out one.
