filling rear tires........
kelsh
06-02-2005 17:55:35
I have a john Deere 4400 and would like to fill the rear tires with anti-freeze solution. What is the correct way to fill them? How much solution? I have lawn tires on the tractor now. Thanks
MATT VR
06-04-2005 18:55:50
 Re: filling rear tires........ in reply to kelsh, 06-02-2005 17:55:35
I used to work at a tire shop, the only thing you really need which is easy to mix up is a few bags of calcium chloride and water, we mixed it one 50 lbs bage to every 300 gallons
Charlie1520
06-03-2005 11:55:57
I used windshield washer fluid and it seemed to work fine. I was able to get the winter version at Walmart for $.89 a gallon, which was a lot cheaper than what I could find for any kind of antifreeze.
buickanddeere
06-02-2005 22:40:38
Windshield washer fluid work fine and isn't a hazmat issue during leaks.
Dug
06-02-2005 21:06:00
I agree with the iron weights as a first choice, CC as a second choice and never going with antifreeze. If you get a leak in a tire, cleaning up the antifreeze will be a nightmare and it doesn't take much to kill an animal. Got any pets?
Dug
kelsh
06-03-2005 11:42:34
 Re: filling rear tires........ in reply to Dug, 06-02-2005 21:06:00
Iam talking about useing RV-Anti freeze.Safe to drink even for people. Wont freeze and tastes great!
msb
06-02-2005 19:42:15
If at all possible, go with iron weights.If you use calcium chloride, the rims are subject to rusting if you get a leak and it is becoming a waste disposal problem if you decide the fluid was not a good idea.Some people are now using beet juice since it won't freeze,but my tire man said the beet juice is a mess to also use.It is sticky and plugged their equipment the few times they tried using it.
msb
06-02-2005 19:41:12
