JD 350 sickle mower
BMD
06-02-2005 17:17:26
I've been looking at a 350 sickle mower. This will not be used for hay,only to keep my ditches trimmed up. It is a 3 pt hook up, and some type of lift mechanism for the blade only. Can someone explain to me how this lift mechanism attaches,I have a 50 , will it work on my 50? Any pros and cons?
ChuckW
06-02-2005 18:41:23
 Re: JD 350 sickle mower in reply to BMD, 06-02-2005 17:17:26
I have a 350 runing on a 520. You will need to alter the lift arm to clear the PTO. If you will email me I will send you 3-4 pics of my setup. I also modified mine for a quick hit to make hook up easy. Email and I'll send pics.
John51
06-02-2005 18:20:45
You need a standard Cat 1 3 pt. hitch. Is that what you have on the 50? Do you have live PTO and hydraulics? It makes it much easier to use. The 350 uses a chain to the drawbar to limit how low the mower frame is allowed to drop. Another chain from the drawbar is used on a lever arrangement to lift the bar as the mower is raised. Sort of tricky to set up but works good. Needs adjusted if you switch to a different tractor. They are a great mower. If Mike Hanley was still around he would give you some tips. One word of advice....get a manual immediately.
BMD
06-02-2005 18:40:24
 Re: JD 350 sickle mower in reply to John51, 06-02-2005 18:20:45
Yes my 50 does have cat.1 hitch with live pto and hydraulics. Thanks for the info, I will give them a call tomorrow.
