4020 charging system
Toby
06-02-2005 17:03:48
My 67 4020 has been converted to 12 volt. I am concerned about how it is wired. The battery terminal on the alternator has a 12 ga wire to the amp meter. There is a jumper wire from the batt terminal to one of the top terminals on the alternator and the other top terminal goes to the switch. I would have though that the Battery terminal would have been a bigger wire and would have gone to the battery by way of the starter solenoid or a fuse block some where. It it set up right.
Toby
John T
06-02-2005 19:32:15
 Re: 4020 charging system in reply to Toby, 06-02-2005 17:03:48
Toby, the necessary wire size from the alternators main output to the ammeter depends on the ammeters current rating, but I usually use a 10 gauge there which suffices for most GM 10 SI 3 wire alternators. However, a 12 gauge will likely not overheat (again depends on alternators rating) even though 10 gauge may be closer to the required spec.
The alternators output MUST GO THROUGH THE AMMETER or else it will not correctly read the current into (via alternators output) or out of the battery. If the alternator was wired direct to the battery or starter etc., its charging wouldnt be reflected in the ammeter reading. ITS WIRED CORRECT TO THE AMMETERS LOAD (NOT to battery) side terminal. The ammeters supply side has but one wire usually, and thats the wire to the starter or battery, while its other load side terminal has loads like lights n ignition PLUS the alternators output. That way the ammeter will register if theres net current flowing into (charging) or out of (discharging) the battery.
Those other wires you mentioned sound right for a GM 10 SI 3 wire or similar alternator. On those the main output post is jumpered direct up to the lil #2F terminal, while the lil 1R requires excitation voltage thats supplied from a switch etc. However, on the GM 10 SI if theres not any other load such as an idiot light, theres should be a 10 ohm current limiting protection (for diodes) resistance between the batterys source (like via a switch) and that lil 1R terminal.
John T in Indiana
Toby
06-02-2005 20:07:18
 Re: 4020 charging system in reply to John T, 06-02-2005 19:32:15
Thanks John T. I appreciate the folks like you that keep the rest of us running. Your knowledge is very valuable to those of us in the learning curve.
Toby
John T
06-03-2005 06:20:52
 Re: 4020 charging system in reply to Toby, 06-02-2005 20:07:18
Youe welcome Toby,
John T
